Results 1 to 7 of 7
Thread: Robot getting stuck on main drain...
    Any suggestions on how to keep my TigerShark from getting stuck on the main drain? Had a "ring" that fell apart on year 3. I see the Smart-Ring, but wonder if anyone else makes something similar. Smart-Ring looks a bit "pricey" for what it is. All your thoughts are much appreciated!!
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Feb 2012
    Phoenix, AZ
    728
    Re: Robot getting stuck on main drain...
    What type of drain cover do you currently have? A new California-compliant drain cover helps spread out the suction..and typically helps cleaners from getting stuck. You can take a look at covers by DrainSafe or AquaStar.
    Blake..I really have no idea at this time. Too cold for me to get in and go look with a mask. Would that be your suggestion or just going with something like the Smart-Ring? I doubt my paperwork from the install (5 years now) would have that info, but I can look. You thinking just replace the drain cover itself??
    How many gpm are you pulling from the MD?
    Support the site
    Probally 25-30+ with a clean filter. I have two skimmers, one main, all 2" PVC. 150 gpm max running 5-10 psi to six returns.
    Try reducing the flow through the MD to see if that helps.
    Support the site
    Got the High Velosity Adaptor from Hayward and haven't had a drain stick ....yet! Will keep trying to see if it works. I know I'm loosing some volumne thru the tigershark, but looks to be covering the pool very well. Will keep you guys posted!!!
