Thread: My "Splash" Pool - Intex Ultra - Base Advice?
    MtnMisty's Avatar
    Mar 2012
    Northern California
    12
    This forum is a gold mine for a newbie like me. Wow.
    I'm hoping to get some input on setting up my dream, errr, pool.
    Here's what I got:
    Intex 18' x 52" Ultra Frame ($175 used, 1 season w/1500 gpm pump, Craigslist)
    Intex 2,650-Gallon Sand Filter Pump (new, Amazon)
    Intex Krystal Clear Saltwater System ($50, used, Craigslist, 1 season, different owner than pool, super friendly helpful seller who sold me his 1yr old blue solar cover for $8 )
    Pool Base Plan:
    Level dirt (my Operating Engineer nephew w/mini-excavator)
    Foam board 3/4" x 4' x 8' http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
    Pond Liner (old, never used for a pond, thick and heavy)
    Does that combo sound sufficient for the pool base? My nephew was saying we should do 4" - 6" compacted base rock + 2" sand + old liner. I like the talk of the foam board and wince at the thought of rock under sand under my pool.
    Oh, in Northern Calif.
    Thanks in advance for input!
    (I call it my "Splash" pool because it's for my Golden, too. That is if she likes it and takes to the training to keep her off the sides! ).
    Intex 18' x 52" Ultra-frame AGP, 8200 gal(?), used
    Intex 2650 Sand filter/pump, new (happy dance!)
    Intex SWG 8110, used
    Intex Wall Mount Surface Skimmer/Vacuum, used
    Solar Cover, used and a Patch Kit, now used.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: My "Splash" Pool - Intex Ultra - Base Advice?
    I would go partially with your nephew, 2-4" compacted crushed rock (screenings), just sand to fill any divots. Then I would use 1 1/2" to 2" foam board. Then a heavy duty tarp on top of the board (the pond liner will work).
    And that is exactly what I did!
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Quote Originally Posted by MtnMisty
    Here's what I got:
    Pool Base Plan:
    I recently put up the same pool and used the same foam along with a heavy duty tarp and we couldn't be happier. We are in Florida, so the ground is sand already. We didn't put down any base rock. Just cleared off the sod/grass, leveled a 20' circle, laid down the 4'x8'x3/4" foam boards with Gorilla Taped seams, put the tarp over it and set up the pool. The legs of the pool are on top of the tarp/foam and settled in approx 1/4" into it but we didn't use any pavers.
    MtnMisty's Avatar
    Mar 2012
    Northern California
    12
    Thanks for input!
    I ended up going with just leveling the ground and 1" foam boards Gorilla taped with the pond liner on top. No divots, love it.
    And, the legs ended up on the foam board, also. 1/4" is about as much as they sunk, too. I had planned on using some flagstone for supports, but things happened so fast when we actually started putting the pool together and filling and attempting to remove wrinkles that I didn't get around to positioning all the legs on the stones in time! But, things seem to have "settled" well, so far.
    Thanks again.
    MtnMisty's Avatar
    Mar 2012
    Northern California
    12
    Oh, meant to mention ... I'm no longer calling my pool my "splash" pool as my Golden doesn't particularly care for swimming. Training her on climbing the ladder sunk in as all I need do is have a hand on her collar and she has the confidence to climb. Training her in the pool to head for ladder, ONLY, took all of 2 swims. She's a smart girl! She much prefers just sitting up on the ladder watching over the activity than jumping in. If she's happy with that, so am I ... I love my pool either way!!
    Hmmm, maybe I'll get a pic of her up on the ladder watching over the pool as my avatar here! That'd be apropos.
