Results 1 to 10 of 10
Thread: Intellichlor Red Light
    My Intellichlor's (1 year old) red light has remained on since they opened my pool. The red light means low salt. I have not cleaned it yet.
    Temprature - 62
    Salt levels - 3200
    FC - 10 - I think they added some when they opened the pool
    Not sure what to do but want to get it resolved before the temps go up.
    Thanks
    20x40 IG, 35,900 gallon, Vinyl, Pentair Tagelus Sand Filter, Pentair Master Temp Heater, Pentair SuperFlo Pump, Intellichlor SWG, Eclipse Auto Cover, Magic Stream Deck Jets
    38,268
    Re: Intellichlor Red Light
    Get you salt level tested independently. You can buy a salt testing kit or at the least have a pool store test it. Then you know what the intellichlor should read and if the salt is really too low.
    Inspect the cell and clean it as that could improve its reading.
    Thanks Jason.
    I have the Taylor salt testor but have not had the reading cross checked with my pool store.
    I will do that next and also clean the cell.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    415
    The Intellichlor will not work or read the salt right until the water temp heats up.
    I believe it is calibrated to be accurate at 77 degrees. Each 5 degree in water temp makes the sensor think it is 200ppm lower in salt.
    You might be able to add a little salt and still be below say 3600ppm, but I just had the same problem so this is how I learned this issue
    with the IC40 system.
    OR just use liquid chlorine for a bit until the pools heats up. At the lower water temp the demand will be low.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Thanks for the input guys, It is appreciated.
    Wanted to post back and let folks know that my Intellichlor swg's red light turned green when the temp hit 68. Not sure of this is the answer but I did nothing else.
    Thanks again for the input.
    Aug 2011
    Texas
    45
    I found this out as well. Anything below about 75* and the cell does read properly. Just keep testing and add bleach if necessary. That's been my process so far.
    12k gal gunite, Sunstone Plaster, Pentair IntelliFloŽ VS+SVRS Variable Speed Pump, Pentair Intellichlor IC-40, Pentair CCP520 cart filter
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Well, consistency is not always there. I've got an IC40 and my temp is about 70, but it's been lower and when I got the salt level correct, it was green light since then. Bottom line, keep checking your FC level even when it's green. Don't get caught not having FC. I check my pool about every other day. Even with a red light, it can still produce FC.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    I also recommend that anyone with an swg get the Taylor salt test kit. The red light on the Intellichlor means low salt which may push one to add salt.
    I had my pool store test the salt level and they read 2000, my Taylor test kit was averaging out at 3200. Only trust your own test kits once you get used to them.
    Jul 2011
    Limerick, PA
    28
    I have an IC-40 and water temp is 60. At 55 degrees or so the SWG will turn off. At 60, once I got my salt in the 3400 range the SWG turned on. With that said, the SWG says optimal is 3200, but the manual says they want salinity between 3000-4000 ppm. The manual also states there is a +/- 500 ppm accuracy tolerance on the SWG so without a reliable salt test kit or electronic test, your are kind of flying blind. It's worth reading the manual on these units, you can learn a lot and reduce the guess work. I also purchased an electronic salt tester from Pulse Instruments. It was worth the money.
    17x39 Rectangular, 20,000 Gal, Plaster, Pentair Easy Touch Automation and Remote
    Pentair WhisperFlow 2 hp pump with Pentair Clean & Clear Cartridge Filter
    Pentair Master Temp Gas Heater, Pentair IntelliChlor IC-40, Pentair Kreepy Krauly Legend II Cleaner
    ..and one frog that thinks the pool is his.
