Thread: Brushing pool walls
    May 2009
    Mn
    198
    Brushing pool walls
    How hard do you need to push the brush against the walls to clean then? I have a vinyl above ground and due to the angle I am outside the pool it is hard to push hard to brush the walls. Is lightly moving the brush over the surface of the walls sufficient?
    Thanks!
    Michelle
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Brushing pool walls
    vinyl pool have a smooth surface so it dosen't require much to brush loose the dirt. If the ammount of pressure you are able to apply is not enough you may need to make more than one pass when brushing
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    The "whale pool brush" allows the brush to stay close to the walls. Do a google on that brush. I like it, but my wife doesn't. She says it's too hard to push down. I like the fact that it stays on the walls much better.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
