Thread: Patch kit reccomendations?
    Hi there. I have a leak in my vinyl pool liner which I need to patch. I have seen several posts suggesting you use liner scraps to patch holes, but all of the patch kits that I have seen seem to have very thin pieces of vinyl for patching. I've also read a lot about the boxer 100 kits, but I've read reviews that suggest the vinyl that accompanies those patch kits are rather thin also.
    Thanks for your suggestions!
    Mike
    30 foot round AGP (25k gal), 2.5 hp pump, Hayward cartridge filter, Diver Dan pool vac, TF-100 Test kit
    -It takes less time to do things right then it does to do it again.
    22,553
    Re: Patch kit reccomendations?
    The reommendation to use liner is partly because it will match the color of your liner and partly because it's thicker. I've used the patch kit vinyl and it holds up fine.
