Thread: Pool Under grouns pop up head not rotating properly
    I have a energy efficient motor, I run it for 20 hours Low speed and 3 hours High speed,
    Problem is :
    I have 13 pop up head in my UG pool, now I see only 3/13 pop up heads rotating properly and IF the other ones pop up, then I don't see the pressure coming out of them ?
    What shall I do to resolve this issue ?
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pool Under grouns pop up head not rotating properly
    First thing to do is open up the cleaner valve and make sure everything inside is in good shape. The gears could have something jammed in them, missing some teeth, etc.
    Quote Originally Posted by Melt In The Sun
    I opened, and everything seems normal, except the O-ring for the valve was little bit loose, do you think that can make a difference ? shall I replace it with a new one ? Thanks
    Oct 2009
    3,899
    Well, it's probably the easiest thing to fix, but I don't see that interfering with the rotation of the zones. Do all the parts spin normally? You should see some kind of fins that the incoming water will spin, which then turns the whole set of gears. If you try and turn these with your fingers, you should be able to tell if it's working smoothly. What brand/model of valve do you have? If you're not sure, post a pic
