Results 1 to 8 of 8
Thread: Upcomming pool owner in Auckland NZ
    East_Akl_Neil's Avatar
    Apr 2012
    Auckland, New Zealand
    70
    Hi all. We have just purchased a house with a pool, will take possession at the end of June. Up untill now the only pool I have had to deal with is called 'The Pacific Ocean' so it is all new to me.
    Stumbled on this site while searching for some information on how to maintain a pool.
    So my mine is bubbling with ideas and question like solar heaters, SWCG, covers, pump run times, test kits, ideal pool chemical levels etc.
    So hi all from NZ.
    Late 1970's 39000L IG Concrete Pool with Vinyl Liner
    Austral FT55 Sand filter
    Hurlcon E170 Pump Brochure,Manual
    32-40mm Pipe work
    Living in beautiful New Zealand
    Apr 2011
    Warner Robins, GA
    245
    Re: Upcomming pool owner in Auckland NZ
    Hello and welcome to TFP!
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    30,419
    Hey, East,
    Welcome to the forum.
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Welcome. It's good to have someone from New Zealand on the forum.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Apr 2012
    70
    Thanks for the warm welcome, much appreciated. I just hope that the pool ends up being this warm.
    32-40mm Pipe work
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Hey! Welcome to this great forum. I found this place after buying a house with a pool in late 2009. Spring 2010 was my entry into learning "how to". I'm on my third year of BBB and it's so easy and trouble free.
    NZ...the home of Hayley, my favorite beautiful voice.
