Thread: Intelliflo VS - did I break it
    Ok..I pulled a dumb move when I closed last fall. Have a one year old Intelliflo VS with an EasyTouch. Blew out the lines, plugged them, and covered pool. Ran out of time so I postponed cleaning the filter and dismantling the pump for another day. I had turned off the pump using the EasyTouch panel controls, but did not switch off the circuit breakers. (I know, I know) Next morning EasyTouch says "lets start up the pump"! But its dry! When I discovered this later that day, the Polaris pump was whinning (no kidding) but the Intelflo was off. As I read the manual, it talks about a Priming dry alarm, which I assume shuts off the pump. (I hope). So my question is ...did I break my almost new pump??
    Thanks for any help.
    22,000 Gal, in-ground ,vinyl. Pentair Intelliflo VS, Clean&Clear 420 cartridge, Hayward NG 300K heater, Polaris, EasyTouch,IC-40, (former Baquacil - converted to SWCG)
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Intelliflo VS - did I break it
    I doubt you broke it, but you probably shaved some time off its life.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
