Thread: Broken Drain Plug in Triton TR60
    Little help guys, I'm a new pool owner. I just broke the drain plug. IT's 1/4", I've ordered a new one and it' on the way. My question is, how the heck can I get the broken plug out of the bottom of the pool filter? Does that round cap the plug goes into twist off also?
    38,000 gal. IG gunite pool -- 20 x 40
    Pentair IntelliFlow VS Pump
    Pentair FNS 48 sf DE Filter
    Sand Shark suction side cleaner
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Broken Drain Plug in Triton TR60
    It's a plastic plug, right? You can try using a cigarette lighter to heat up the blade of a flat screwdriver, then push it into the plastic when it's nice and hot. It should melt a little slot for itself and you can screw out the plug.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Propane torch, works much better and faster.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
