Results 1 to 10 of 10
Thread: Broke my drain plug....
    how do I get the broken one out?
    38,000 gal. IG gunite pool -- 20 x 40
    Pentair IntelliFlow VS Pump
    Pentair FNS 48 sf DE Filter
    Sand Shark suction side cleaner
    30,426
    Re: Broke my drain plug....
    drain plug to what?
    If this is for the pump, I also did this just last month. Twisted it to tight and SNAP! I used a screw extractor VERY carefully. Making sure to stay perfectly in the center of the plug, not to ruin threads on housing. It worked as designed. Good luck!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    warning......those things only seem to work 1/2 the time. If you're lucky! I've NEVER had good luck trying to extract a broken screw of any sort.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Heat flat tip screwdriver up with propane torch, when hot insert tip into drain plug just a little way then pull screwdriver out. Quench the tip in water to cool. You now have melted a slot in the drain plug you can stick the screwdriver into to back the plug out.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Quote Originally Posted by Leebo
    I think they work all the time if done right...
    Agreed it was scary and if you get off center, threads on plastic housing could be messed up. Flat head screwdriver with torch sounds safer.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Melting a slot is worth a try.
    Myself? I have thousands of dollars worth of mechanic's tools. I'd start with a left-hand drill bit; very often they'll snag and unscrew whatever in a hurry. Kids, don't try this at home.
    Yes this is my pool pump, triton tri1 sand filter
    Apr 2012
    151
    Is it flush, or is there a little sticking out? Could you get some vice-grips on it?
    I like the screwdriver idea...I will use that!
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
