Results 1 to 12 of 12
Thread: Help with getting my wife's hot tub running
    Nobody's happy if moma's not happy (with working hot tub)...... I was hoping to get some suggestions on getting my hot tub running. I believe I have a bad motor--may be locked up. When I turn on the switch, it just makes a humming noise. The motor won't turn over nor will the shaft turn. It set for a while without running (about 3 months) and when I went to crank it up, nothing.
    I thought of taking the motor out, but I'm not sure how easy that will be. Here are a couple photos of the motor.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,589
    Re: Help with getting my wife's hot tub running
    Sounds like it could be the capacitor....which is under the back cover and looks like an overszed turn signal flasher in a car....round metal tube with 2 prongs. See if you can get just that out and test it. On second thought, yours could be right behind what looks to be a service panel on top.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Shaft won't turn at all? Try with a wrench if you can't turn by hand.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Quote Originally Posted by woodyp
    The service panel is the blue door, correct. I think I can open that door. Is that where you're talking about?
    Quote Originally Posted by maxepr1
    It won't turn. I've tried the wrench. It is stuck for sure. It ran fine when we shut it off.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    If you can't spin the shaft, momma's gonna need a new motor!
    That's funny. Would you see about re-building this one or just get a new one? I think a re-build is around $70 to $80 (at least that's what a Hayward re-build cost). I have not done a search yet for a new motor....got any recommendations on where to find motor?
    jed
    Apr 2010
    East Texas
    9,589
    My bad. I didn't realize you had tried to "physically" turn the shaft. Just thought you didn't see it spinning when you tried to fire it up. I'd have it rebuilt if I could for a reasonable price.
    So, to remove the motor, it looks like these nuts to come off. Any more suggestions?
    22,548
    The easiest thing to do is remove the whole pump. The bolts at the suction and discharge fittings and the foot bolts. If you remove the bolts you pointed out you're still going to have to unscrew the impeller and that's not going to be easy. Besides your problem might be in the wet end any way and you'll wind up pulling it anyway.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Jed, sure you might be able to take the motor to a shop in your area where they can overhaul it for you. But price out a new one first and then call motor shops. In my area they want 75% of the cost of a new motor to overhaul the motor! I ended up temporarily replacing a bearing until I buy a new pump!
    Thanks everyone. I'll see about getting that thing out this weekend.
    jed
