Results 1 to 9 of 9
Thread: How to position pavers for support legs?
    18x52 Ultra Frame.
    I have leveled the ground in a 19' circle. From reading posts on this site I understand that something to increase surface area needs to be placed under the support legs to prevent sinking. I also understand that they need to be recessed to approximately .25" above the pad surface, positioned to prevent touching liner and have the support legs well onto the surface. Apparently the legs shift while filling the pool so this seems like a difficult procedure given all the variables. What is the approved solution?
    I installed the pool last year but took it down at the end of season because the pad was not quite level. I did not notice the legs having sunk but could have been the off-level situation making it unnoticeable. The soil is hard packed sandy clay or clay sand but does get a little mushy on the surface with rain.
    docchop1's Avatar
    Apr 2011
    Southern Indiana
    61
    Re: How to position pavers for support legs?
    This is how I do it and so far so good. I position each leg on the inside edge of my 1X1 foot pads. In this picture it's 1 1/2 inches treated plywood dug in flush. When I fill the pool the legs tend to splay out some and with the help of the ground rope the legs end up just about in the middle of the pads. You don't want a lot of tension on the rope but a little is ok. Also, make sure the top rail is round by measuring many points across the circle before you place and dig in the pads. It's a good idea to dig those pads in flush too because if they are proud of the surface you may feel them through the liner.
    Intex 15x48, Intex Saltwater Chlorine Generator, Intex 14" Sand Filter, TF-100 unicorn eating spaghetti while riding a unicycle on a high wire during a storm edition test kit,
    http://tftestkits.net
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    docchop1, nice job on the explanation and picture.
    Yours is the blue walled type intex, is it not? I wonder if the spring out of the legs is the same for the ultra type? Either way, that is a lot of movement. Any reason why you used wood instead of patio block?
    I agree keeping the block flush makes good sense here.
    docchop1's Avatar
    Apr 2011
    Southern Indiana
    61
    Yes mine is the blue wall Intex and it will be interesting to hear if the ultra pools legs kick out as much. Some of the pictures I've seen on these forums suggest they spring out some. Maybe an ultra owner can shed some light.
    Nope no special reason that I used wood pads on part of the pool this year. I didn't have enough pavers but I did have a bunch of 3/4 treated plywood scraps so I doubled them up and stuck them in the ground. Seemed like the thing to do.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I would switch to a paver instead of wood. You going to have rot and it will become a problem down the road.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    The Ultra's legs will splay out like the blue/white, just not as much. I would guess 2-3"?
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    docchop1's Avatar
    Apr 2011
    Southern Indiana
    61
    Max I agree that down the road it would be a problem but the four months this pool will be up is a pretty short road for this type of plywood. No worries.
    racerboy6996's Avatar
    Aug 2010
    Albemarle, NC
    103
    before I upgraded from the round intex, I used the composite decking board cut into squares under the legs. At least for me they worked perfectly
    Intex 16ftx32ftx52in rectangular / Hayward 2 speed pump / Hayward 21in sand filter / Intex SWG / still saying solar panels coming next year
    Thanks for all the input. So I need to assemble the frame and place it on the pad to mark the block placements? The frame on my pool snaps together with flimsy plastic tension buttons and holes. I don't think I would want to try to move it once assembled especially with the liner attached so I would want to disassemble once block location is marked? I would assume that the legs would need to be placed on the round frame, unlike docchop1's photo, in order to assure the leg insert of the T fitting were vertical and level? There is so much play in the frame fittings I doubt the frame alone would be very stable without the liner although I haven't tried. Given the amount of play in the frame, even with measuring like docchop1 suggested, I am doubtful that I would be able to get the legs to strike the same place after reassembling w liner and then filling w water.
