Results 1 to 8 of 8
Thread: Small Brown Stains Just Appeared After Lawn Service?
    Hi all - yesterday I had a medium sized tree pulled from my backyard along with having the stump removed (through a grinder process). The tree was originally about 15 feet away from my pool.
    Upon coming home from work to check out the job, I looked at my pool and there were a ton of small brownish (even rusty looking) spots on that side of the pool closest to the where the tree was removed, appeared to be a splatter pattern that got less frequent as you moved to the halfway point of the pool. These spots were not there before.
    Any what could cause this? My krauler running all night seemed to have lessened the effect on the pool floor but the stairs still look pretty bad...
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Small Brown Stains Just Appeared After Lawn Service?
    Probably some kind of an metal deposit from the machine or dug up fertilizer. It will probably go away over the next few days.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Can you brush them off? Are they on the side of the pool or on the bottom? I can imagine tiny bits of metal sinking to the bottom and leaving little stains.
    I was not able to brush them off yesterday afternoon with a few minutes of effort...however the floor ones appeared to fade somewhat overnight, not sure if that is the rewult of my krauler running over the area all night
    After looking at some other stain threads, is there any chance this spreads? Any way to remove easily?
    30,421
    Don't know what it is. Can you post pics. You need to identify the stain before you can figure out how to get rid of it. If you have a tri-chlor puck you can hold it on there for a few minutes and see what it does. If it removes or lightens it, your stain is organic and can usually be removed with elevated levels of chlorine.
    If that doesn't work, crush vitamin C tablets, put then in a sock and hold them on the stain. If it removes or lightens it, the stains are metal and you may need an ascorbic acid treatment
    Feb 2008
    Denton, TX
    5,061
    Organic stains will go away on their own in a couple of days as long as your pool is properly chlorinated. If they don't go away, it is probably some sort of metal. As maxepr1 mentioned, the fact that they appeared after a landscaping company came onto the scene makes me think of iron bits from fertilizer.
    May 2012
    Arcadia, Ca
    50
    I'm new here, but an old pool owner. I'd bet they fertilized with iron and some dropped into the pool. I've done it before. It'll stain your deck, sidewalks, you name. The bags themselves will warn to wash off concrete etc.
    24'x15' 4.5 deep (avg) 13000 gallon pebble bottom in ground playpool
    Cartridge filter with a hayward 2.5hp pump.
