Thread: TA Levels in plaster pool
    May 2011
    Los Angeles, CA
    228
    Hello everyone!
    Should I raise the TA so that the CSI is 0 to a positive number to protect plaster?
    Pool Calculator says 70-90+ and it says a TA of 130 is required for CSI to be just on the positive side without borates and 0 with borates at 40 ppm.
    Right now I am shocking the pool with the following readings:
    FC = 24
    CC = 0
    pH = 7.5
    CH = 260
    CYA = 55
    TA = 90
    Temp = 72
    Borate to be added to 40 as soon as shocking is over.
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    38,237
    Re: TA Levels in plaster pool
    I would think you would be better off bumping up the CH and keeping your TA lower to help hold your pH if you are concerned with you CSI. But being a little negative is not that bad I don't think.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    With 24 FC, your pH is suspect. So don't do anything until the shocking is done and FC is below 10 and you get numbers that can be trusted.
    Anywhere between -0.6 and +0.6 is okay on the CSI.
    May 2011
    Los Angeles, CA
    228
    Thanks for the replies....
    It has been a character of the pool that the pH keeps rising with the TA lurking around 90-100. I noticed that last year soon after i brought the house.
    How are TA and pH related? The lower TA the higher pH?
    Thanks!
    38,237
    TA is a buffer for pH. If TA is too low tgw pH can swing wildly. If TA is too high it will pull the pH up.
    If you are constantly fighting to hold pH down. Try lowering TA using the process described in pool school.
    May 2011
    Los Angeles, CA
    228
    Thanks!
    That explains a lot!
