Results 1 to 20 of 20
Thread: Done with Pool School - Now come my questions!
    Apr 2012
    49
    Hello everybody. I am new to TFP and relatively new to pool ownership. I have found this site to be very helpful and have recently gone through the shock process to eliminate algae from my pool. I am now working on getting everything in balance and ready for the swim season. I have an 18,000 gallon in ground SWCG pool with spillover spa and a separate waterfall. The water currently looks great. Here are my current readings as of this morning:
    FC 4
    TC 4
    CC 0
    PH 8.1
    TA 160
    CH 380
    CYA 30
    Salt 2800
    I did the tests myself with the Taylor K-1005 for PH, TA, CH and CYA. I used the Taylor K-1515 FAS-DPD for the chlorine tests and the Taylor K-1766 for the salt.
    Based on output from Pool Calculator I added 250 ounces of 14.5 acid this morning after the reading to lower TA and PH. It looks like I also need to bring my CYA up to at least 60 because I have a SWCG and I also want to get my salt up to about 3100. So now my questions:
    - Does it matter in which order I raise CYA and salt? Can I do both at the same time?
    - How long should I wait to do my next TA test and do I keep lowering with more acid each time the PH has returned to normal range?
    - Does my spa spillover contribute to PH rise as I run it each time my filter is on (8 hours a day)?
    - Anything else based on my test results?
    Thank you.
    ____________________________________________________________ ___________________
    21,000 gallon in ground rectangular plaster pool, Sta-Rite High Rate Sand Filter Model 82524-3, AO Smith SK1152 1.5HP motor w/ Sta-Rite bronze pool pump, Hayward Navigator
    Re: Done with Pool School - Now come my questions!
    Welcome to TFP!
    It seems you are off to a great start
    You can do CYA and salt at the same time.
    I would test the PH occasionally and test TA the next time PH is up to 7.5, then if TA isn't down to where you want lower the PH to between 7.0 and 7.2 again, repeating as needed until TA is down where you want it.
    Yes, the SWG, spa spillover, and waterfall all contribute to aeration, which raises the PH.
    I would aim for a CYA level around 80. However it is best to go there in a couple of steps so you are sure not to raise CYA too high.
    Feb 2012
    Phoenix, AZ
    728
    Hello and welcome to TFP!
    By the sound of things, you have a pretty good handle on what needs done!
    The order of CYA and salt will not matter. You can do both at the same time if you want.
    I am not sure of the minimum time you should wait to measure TA, but I think tomorrow would be a safe bet.
    Yes, your spillover will contribute to pH rise.
    EDIT: Well, Jason beat me to the punch..oh well.
    Welcome and keep up the good work!
    Apr 2012
    49
    Thanks Jason and Blake. I appreciate the confirmation that I am on track.
    I now understand the TA approach. Keep cycling with acid every time my PH gets high enough (7.5+) and until the TA is at the level I want.
    So, if the spa spillover contributes to PH rise because of the aeration, what is the best way to chlorinate my spa without using the spillover? Do I run on pool setting with 100% pool return for 8 hours with the chlorinator set at one level and then the spa setting with 100% spa return for X hours with cholorinator set at X level? Is that how most people do it with this combination? Right now I run the filter on pool setting for 8 hours with the return set to 50% pool and 50% spa and the spa spills over into the pool because of the way I have the valves set. Does my question make sense?
    You need to run the spillover at least a bit each day. There is no complete work around for that. Depending on your setup it might be practical to lower the amount of water flowing to the spa, or only send water to the spa for half an hour or an hour each day.
    In most cases you can lower TA enough that PH increases stop being a problem. The rate at which PH goes up depends on many things, but the two most important are high TA and the amount of aeration. By lowering TA and reducing the amount of aeration you should be able to get it completely under control. That works for the great majority of pools, but every now and again there will be a pool where the PH still goes up.
    38,279
    Welcome
    I just wanted to say thanks for doing your homework and reading through Pool School before posting your straight forward questions.
    You seem to have a good understanding and should be able to enjoy crystal clear pool all summer.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    You seem to understand using acid and airation to lower TA and since you need to lower your TA anyway, the spa spill over will help with aeration. You may find (like I have) that striking a balance between how much water returns to the pool and how much goes to the spa will help maintain that lower TA that you need. I've found that I always need a little spill over, just not all the water going that way. Yes, it does raise the pH a bit, but unlike the SWG, it does so with out increasing the TA. Then when you add MA you lower both pH and TA.
    chiefwej
    Apr 2012
    49
    Jason (jblizzle) and chiefwej it looks like all three of us are from Tucson. It's already swim time here. My family had its first swim day two days ago on Sunday. This is earlier than last year if I remember correctly.
    chiefwej - Based on your signature it looks like you and I have very similar systems except you are on a DE filter and I am sand. Are you adjusting the spill over manually, or is it on automated control? If you adjust it manually, do you leave it in the same position all the time and have the spill over going whenever the pool filter is on? What is your second pump for...some type of water feature?
    38,279
    Quote Originally Posted by mcdickey
    There are a surprising number of us Tucson folk here ... wonder if everyone got sick of Leslies? I let the girls get in a few weeks ago ... water was still low 70s ... they did not last long. We went again on Sunday and the water was closer to 80 ... still a little too cold.
    Need to get my solar heater back up and get the water temp up ... although if I wait much longer, I will not need it until the fall.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I had to turn the solar off yesterday when the pool temp topped 90. We have been using the pool for almost two weeks now.
    Re. my spa return, I actually have a fountain in the spa that I use to provide a bit of aeration. My pool has separate valves for almost everything, so I just put a little bit of water through the fountain all the time the filter pump is on. My second pump runs the gas heater and spa, but can be diverted to the pool if I want to heat it with the gas unit.
    The problems here in Tucson seem to be keeping the TA down, to combat constant rising pH and my CH seems to always be in the 500+ range. This site has taught me so much and adding borates has made managing things a lot easier.
    chiefwej
    Apr 2012
    49
    Thanks guys.
    Apr 2012
    49
    I added 6 pounds of CYA over the last 48 hours. I'll test the levels again in one week and see if it gets me where I need to be. I am shooting for 70 PPM after the additional 6 pounds and then will slowly bring it up to 80 after that.
    Apr 2012
    49
    Ok, so I added CYA last Saturday (6 pounds) and waited a full week to test. I also added 40 pounds of salt. Here are my results from a few minutes ago:
    FC 5
    TC 5
    CC 0
    PH 7.9
    TA 120
    CH 390
    Salt 3100
    CYA 90-100
    Here are my thoughts...It looks like I was able to bring TA down from 160 to 120 last time with the acid. It also looks like my PH is high enough now to bring it back down to 7.2 again to attempt to get TA even lower. Correct?
    It looks like salt ended up exactly where I wanted it to.
    I over shot CYA. I was hoping to be around 80 and ended up in the 90-100 range. Is this an issue and do I need to drain some water out and refill to get it down to the 80 level? Or can I leave it how it is without really bumping up the FC?
    Thanks in advance for your input.
    Adding acid now to work on lowering TA a bit more would be great.
    You should be able to get by with CYA there, just keep FC at 5 or higher and don't add any more CYA for a while.
    Jun 2008
    Marana, AZ
    347
    Oooh, oooh, oooh! I have to join the party here! Tucson area myself.
    Swimming a lot now. I have a canopy over my pool made from solar screen fabric so I don't fry. I also have a solar cover so the early morning and late afternoon sun warms the water, as well as not much cooling of it at night, so my water temp. is lower 80's. Happy swims!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Apr 2012
    49
    If I don't want to just "get by" how much water should I exchange to get CYA to 80? My pool is approximately 18,000 gallons and I believe my CYA is about 100? Is there a formula for this?
    30,419
    It is a direct reduction. If you remove half of your pool water, your CYA, when the pool is refilled will drop by half.
    Apr 2012
    49
    That makes sense. So I need to take out about 20%...3,600 gallons. That's a lot of water. Oh well, live and learn.
    Apr 2012
    49
    After researching more on the CYA test and how to correctly read results, I now believe my CYA reading is somewhere between 80 and 90 with my Taylor K-1005 test kit. I did the test again this past weekend with my back to the sun and the vial around waist level and added until the black dot completely disappeared and did not reappear. After repeating the test about 5 times I consistently had results in the 80-90 range (versus the 90-100 I was reading before). I had my wife do the test as well and she came up with 80. Given the +/- range of 10 with the test I think I am in good range for my SWCG pool. I am going to reduce FC back to about 3 PPM (was at 5 PPM) and see what happens.
  20. Back To Top    #20
    Apr 2012
    49
    Updated test results from last night:
    FC 4
    TC 4
    CC 0
    PH 7.2 (I just added acid yesterday morning to bring down TA)
    TA 90
    CH 380
    CYA 80-90
    Salt 3100
    I am almost where I need to be and the water looks great.
