Results 1 to 8 of 8
Thread: Hard Plumbing
    rich3955's Avatar
    Apr 2011
    Utah
    2
    Hard Plumbing
    When hard Plumbing your AGP is it ok to bury the pipes or is it best not to leaving them on top of the ground
    I have a path way around my pool making it nice when cleaning, covering, maintain etc... I just don't need to trip over some pipes.
    18' Round 54" High AGP, 8500 Gallons, Waterway 2 HP/2 Speed Pump, 150 sq ft. Waterway Cartridge Filter, Hard Plumbed.
    Re: Hard Plumbing
    I don't see why not. I'm sure it would look much better and if it would be in the way otherwise, that's a good idea. Since my equipment pad is off to the side I didn't really think much about it.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Re: Hard Plumbing
    If the pipes are buried and you need to winterize the pool you will need to blow the water out of the pipes, as would be done for an above ground pool. With pipes above ground you don't usually need to blow them out because you can usually position a drain low enough to get all the water out. Other than that, burying them is just fine.
    Mar 2012
    Amarillo, Texas
    341
    Re: Hard Plumbing
    Ours are buried. My husband did it that way because it was easier to get lawn equipment in and out.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Hard Plumbing
    Also plan for potential frost heaving and how it could impact connections to skimmer or return port.
    I'm doing the same project this summer and the plan is to use pvc unions in certain places so I can disassemble and store - pump has to come into garage anyways.
    Jun 2012
    Staten Island NY
    34
    Re: Hard Plumbing
    I think the use of TigerFlex pipe would take care of frost heaving. My question is how do you blow the pipes out. With a compessor and ........?
    12x21 AG-semi-inground about 7200 gal, Cart filter,1.5 hp pump installed May 2012
    TF-100/BBB
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Hard Plumbing
    You could also vacuum them out with a shop vac or even blow them out with a shop vac. Just another option. I plan to bury mine.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    22,550
    Re: Hard Plumbing
    I use my leaf blower.
