Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Central Texas Fiberglass Pool Build
    We started our pool build yesterday. We decided to go with Lonestar Fiberglass Pools out of New Braunfels/Kingsbury. The model we picked is called the Savannah in a Caribbean Blue.
    ____________________________________________________________ ______________________
    In the process of building a Lonestar Fiberglass Pools : Savannah in Caribbean Blue. 13,000 Gallons SWG, 4 therapeutic jets, Pentair 1 HP superflow (348023) pump, 200 Clean & Clear cartridge filter (CCRP-160353), Pentair salt cell IntelliChlor IC40, 3 LED lights, 1 skimmer, cantilever coping with integral light wheat color, and salt-rock pool decking finish.
    Re: Central Texas Fiberglass Pool Build
    Here are some more pictures of them setting the pool. The plumbing is being done on Wednesday.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    is that even close to level? I assume they'll take care of that! Looking forward to watching the progress.
    The pool is actually level with the patio. I didn't think it was level at first either, but they used this box device that was on the patio and used a stick with an electronic device measuring around it. It would beep as he moved it around and a long beep indicated it was level with the box device. The ground itself slopes a bit but once everything is done, we will backfill with top soil and lay new sod.
    Oct 2009
    3,899
    OK, glad it is Man, pictures can be deceiving...that thing looks like it's 18" from level!
    I was a bit worried too. I think it is because more of the hole is exposed on the left side from the picture angle. I am not sure if that is due to more plumbing going in on that side or what. I have checked out some of their other pool build installation pictures and I see the same thing on them as well and the finished pool looks "normal".
    Plumbers came today. Here are some pics.
    Here are some pictures after they were done and back filled with gravel from different angles.
    Tomorrow they come back to finish the plumbing, setting the pumps and stuff up. I assume Monday the tile work and framing for the concrete will be done. Then later that week, the landscapers come. I'm hoping to be swimming by next weekend.
    Oct 2009
    3,899
    Moving quickly! Please keep the pictures coming!
    Not much done today. Won't be back out until Monday. Here is what they did today....I guess everything looks okay.
    Western Pennsylvania
    151
    It looks like you are set up for a pressure side cleaner, that valve will send all the return flow to the cleaner port or the returns.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    Oh for the Polaris. Thanks. We are probably going to make them redo the plumbing. It doesn't appear they dry fit everything first to make it squared. My husband is ticked off about how they just slapped it together.
    Concrete guy came today and set forms for the cantiliver coping decking. My husband made 3 of the PVC T post with screw on cap as we have seen made on this website. We are placing 2 on the backside of the pool to help block afternoon sun and the third one will be used to make a towel tree to hang towels and wet suits.
    I will have to take pictures in the morning as it was a bit dark when we got home this evening from baseball.
    Here are some pictures of what the concrete guy did for setting up the forms and our homemade umbrella stands.
    Hoping they will come today to pour.
    Concrete decking is done. Tile was suppose to be completed this weekend but that didn't happen. I'll post pics later today.
    May 2012
    Northern Connecticut
    103
    Need more pictures. Can't wait to see the towel holder
    Sandy
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Enjoying the pics as a fellow fiberglass pool owner.
    Just an FYI- I had to really scrub (!) to get all the sticky residue off the sides left from the foam forms that were used for the coping edge. If yours has any, ask your PB how it gets removed and who has to do it? I waited between November and April and it may have been easier had it been done immediately.
  20. Back To Top    #20
    Here are some pictures from the concrete and electrical setup.
