Thread: A little shade was called for
    When I was doing some research for this project I found very little information so I thought I'd post a few pics and information
    We've got a 20*20 foot concrete patio off the back of our house on the way to a small in ground pool (12*24). The patio is quite nice but basically unusable in the summer here without any shade! I was seriously interested in an Alumawood solid roof but due to the snow load here in the mid-Atlantic region the footings needed were substantial and would have required cutting into the patio.
    Thought about a Sunsetter retractable deal but they only go out a max of a little over 11 feet. I wound up with the system from ShadeTree - http://www.shadetreecanopies.com . Very happy with the results, the canopy is 16' wide and projects 15', each section is retractable seperately and when retracted it tucks up under the eave. I did some prep work before the tracks and fabric arrived, took about a day and a half to build the wood frame from materials acquired locally and I stripped off the vinyl siding / installed a ledger board and flashed it in. Once the shipment arrived it was about a 5 hour project to erect it with a bit of assistance here and there from my wife.
    12*24, 8,600 gallon vinyl inground, 12*18 H2otsun solar panel, Polaris ATV, 1hp Superpump
    Dec 2010
    San Diego, CA
    1,137
    Re: A little shade was called for
    Nice job!
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Butterfly's Avatar
    South Carolina
    10,045
    Looks nice and thanks for the info.
    You're done SLAMing when:
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Looks good!
    Wow this looks really nice.. Thanks for the idea.
    Jul 2013
    Waxahachie, Tx.
    446
    That looks nice, i have the same situation. I have looked at many different types of patio covers. I looked real hard the http://www.shadetreecanopies.com canopies. But I haven't pulled the trigger yet.
    Have you had yours long enough yet to know how well they hold up.?
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
