Thread: Idea... Dissolving CYA in the Liquidator
    I'm not having much luck dissolving CYA via the sock method in front of a return... So I had the idea of dumping the CYA into the Liquidator. I figure it will sink to the bottom and dissolve over a week or so. And I won't have to worry about undissolved CYA getting lost while backwashing. Any thoughts or constructive criticism? I don't want to cause an explosion or melt my Liquidator
    10,800 gal Quartz pool with attached spa
    Pentair Intellichlor-IC40
    Pentair IntelliFlo4 160
    DE Filter: FNS P60 Vertical Grid
    30,431
    Re: Idea... Dissolving CYA in the Liquidator
    I think using the LQ would cause some other issues but I don't know for sure. They WILL dissolve in front of the return in time or, if you do not intend to backwash for a week or so, simply let the CYA get pulled into your skimmer.
    Definitely do NOT put any other chemical in the liquidator other than liquid chlorine (sodium hypochlorite). Hypochlorites and cyanurates do not get along.
    The reaction of an isocyanurate with hypochlorite can result in rapid formation of nitrogen trichloride, which at high enough concentrations will detonate spontaneously with great violence.
    http://www.taylortechnologies.com/chemi ... ntentid=73
    Support the site
