Results 1 to 8 of 8
Thread: Chlorine level in the winter.
    Sep 2011
    Atlanta Ga
    310
    Winter is a long way away, but I am just wondering, if I decide to leave the pool open and uncovered next winter, do I keep the chlorine level the same, or can it go much lower because of the cold?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Chlorine level in the winter.
    You'd probably want to keep it about the same, but usage should go way down.
    Sep 2011
    Atlanta Ga
    310
    If sunlight is hitting the pool in winter, why does usage go down? I thought it was just the sunlight that broke down the chlorine, but are you saying it is also temperature?
    27000 gallons
    Pool built in 1971.
    SW Indiana
    9,199
    Colder water has less biological activity and you probably have zero bather load too. Both contribute to chlorine consumption.
    38,463
    What John said ... and what I already wrote ...
    Well, in winter the sun is not quite a strong. Also, when the water is cold, there are less organics for the FC to have to deal with (no bather load, no algae trying to grow, etc).
    Sep 2011
    Atlanta Ga
    310
    I see. Thanks for the info.
    27000 gallons
    Pool built in 1971.
    Sep 2011
    Atlanta Ga
    310
    When shocking a pool, is the high chlorine level ever high enough to be a health hazard? Is it OK to swim while shocking?
    27000 gallons
    Pool built in 1971.
    38,463
    It is generally accepted as safe to swim up to shock level for you CYA level. If you are shocking with FC above shock level and trying to kill stuff ... swimming may not be the best idea.
    If the water is clear and you are close to passing the OCLT and FC is at shock level ... it is probably fine ... may want to rinse you suits etc after.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
