Results 1 to 8 of 8
Thread: Pump not working-- what do do while waiting on repair
    East Texas
    18
    My pump is not working correctly -- the pump itself will run but the drive (control panel) part is not working correctly and it's not coming on and off at the scheduled times nor can we override the scheduled times if needed. The drive is bad, it's under warranty, and Pentair is sending a repair tech and new drive.
    In the meantime, what do I do to try to keep my pool in shape? I'm not sure how long we'll be down or how much I can rely on the pump (and thus salt cell) to work.
    How do I maintain the chlorine level and keep the ph in check if no circulation?
    Thanks for your help!
    22,700 gallon, 16x38 rectangular gunite pool with midnight blue quartz plaster, SWG (Intellichlor IC40), Pentair VS pump, Pentair Clean & Clear Plus cartridge filter, lakefront property
    38,475
    Re: Pump not working-- what do do while waiting on repair
    I am confused. Will the pump run or not? You state it runs but the control panel is bad. I am surprised there is no way to just get the pump going.
    You can just use bleach to add chlorine and acid to adjust pH based on what your test show you need and the poolcalculator.com for dosages ... although neither may be a good idea without circulation.
    East Texas
    18
    We can get the pump going but then it shuts off outside of the scheduled/programmed times, so that's why I'm not sure how reliable it will be as in how long I can keep it running to circulate water. I cannot adjust the pump speeds either, so when it runs, it runs on a low speed.
    I should've been clearer. My question has to do with what you, Jason, said: without circulation, is there anything I can do to keep it in shape? I didn't know if I could add bleach and acid without circulation.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,101
    If you happen to have a sump pump you could toss that in just to circulate the water while adding some bleach. Not sure I'd add that much at once just in case however.
    I'd also use a solar cover until the pump is back up and running. Help keep some of the evaporation of the chlorine to a minimum.
    edit....Ahh...so the pump does run sometimes. Then just add some bleach on your own and let the pump run for about 30 minutes to mix it in. Cover back up and let the pool take it coarse. The cover will keep much of the chlorine in for you.
    22,553
    Ditto what Leebo said. If the pump will run at all just dump some FC in there and let the pump run for a little while to mix it up. When that fails you can dump soem in it and use a brush to mix it up well while brushing the pool which should be done anyway.
    Bucks Count PA
    73
    I had the same problem last summer with my pump going down. I just added the liquid chlorine and brushed the pool to circulate the chlorine. I would go around the pool 1 or 2 times to move the chlorine around.
    Inground Grecian 20,000 gallons vinyl liner
    Hayward 250 BTU Propane heater
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    May 2011
    Clearwater, FL.
    446
    I would think that if you could run the pump for about 30 min. is all you need after adding chlorine.
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    I would add chlorine and brush well with the Wall Whale brush, it moves a lot of water.
