Thread: Adding CYA
    Apr 2012
    Lees Summit, MO
    21
    Adding CYA
    Hello TFP. Opened using BBB this year. I began shocking Friday 4/20. I'm now adding 6 pounds of CYA to go from 0-20ish. I started yesterday filling socks and putting them in front of the 3 returns. Very little has been distributed when I periodically check the socks. Seems it will take a week or so to add the 6 pounds. I have been sprinkling a very little around the pool as well.
    Should I add it more rapidly or am I on the right track? I think I read the numerous posts about adding CYA. Thank you.
    20x40 inground, fiberglass 3 foot down then vinyl.
    36,000 gal
    1.95HP Hayward Super II pump
    Posiflo 2 Cartridge Filter 135 sq foot
    Jandy Lite 2 400 Natural Gas heater.
    This morning
    FC -8
    TC- 8.3
    TA- 80
    CH- 120
    PH- 7.2
    CYA- didn't do
    Temp- 60
    33,000 gal
    BBB
    Sta-Rite System 3 DE 37 sq ft
    22,553
    Re: Adding CYA
    You can massage the socks whenever you walk by to help it dissolve faster. I usually can't leave them alone and it'll wind up dissolving in about two days.
    Apr 2012
    Lees Summit, MO
    21
    Re: Adding CYA
    Thank you!
    33,000 gal
    BBB
    Jan 2010
    Northern Virginia
    282
    Re: Adding CYA
    Last year I added my CYA directly into the skimmer basket/return. I poured 1/4 of the total amount into both skimmer baskets (for 1/2 the total amount), and then a week or two later I added the 2nd half of the dosage (1/4 per basket).
    It worked well as far as I can tell.
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Adding CYA
    You do not want any chemical sitting on your liner. Best to vac it up and let the filter catch it.
    Welcome to the forum
    You're done SLAMing when:
    Apr 2012
    Lees Summit, MO
    21
    Re: Adding CYA
    The massaging is working well. I don't see any sitting on the liner so I assume it disolved. Its still pretty cloudy though. I brush it every now and then to stir it up. Thanks for the advise!
    33,000 gal
    BBB
