Results 1 to 11 of 11
Thread: Should I buy this pool?
    Jul 2011
    NW Iowa
    11
    I found a used Doughboy pool online for $2000, it is 3 years old, and appears to be well taken care of. We would love to upgrade to a pool of this size.
    This is some of what the owner says about it-
    This pool comes complete with a solar heater AND a solar cover, pump, automatic cleaner, manual cleaning system, chemicals, and pool toys. It is 20 x 38 and 4 foot deep. The liner had a 10 year warranty, seven years left.
    I would be responsible for taking it down and setting it up, which doesn't bother me at all. My biggest concern is how the liner will be after I set it back up.[attachment=0:u5lwipxq]omaha1.jpg[/attachment:u5lwipxq]
    Jul 2011
    NW Iowa
    11
    Re: Should I buy this pool?
    Here is another picture.
    [attachment=0:2k2m5o6m]omaha.jpg[/attachment:2k2m5o6m]
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    If the pool is 3 years old you may have to buy a new liner when you set it back up. There's a good chance it will shrink when the pool is drained.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I agree, liners are rarely reusable unless specific precautions are taken before draining and even then its a gamble. Other than that, its good deal for all that. Buy a liner.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Jul 2011
    NW Iowa
    11
    So you think even if I had to buy a new liner it would be a good deal?
    What special precautions can be taken before draining?
    Does anyone have a recommendation of where to get a replacement liner?
    Thanks for your input.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Doughboy pools require their own liners due to sizing specifics. Look for a dealer listed with the BBB and price shop. A liner may possibly survive removal and replacement if kept wet the entire time to prevent shrinkage but its impossible to put back in exactly as it came iut and if it does fail you have lost all that labor, sand, water and time.
    22,543
    At 3 years old I think it would be worth a little effort trying to save that liner. I would get a large tub and when I drain it I would put the liner in the tub to protect it and keep it from drying out. The biggest problem you're going to have is lining up the skimmer and return but with some help you should be able to get them back in place. I'd recommend setting it with a shop vac before the first drop of water goes in it. That way you'll know if it's going to go back into place.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I'd recommend watching a few videos on installing an oval AGP so you know what your up against, the sides have to be done a certain way and it will be some significant labour. Not saying you can't do it, but just make sure you know what your up against.
    Jul 2011
    NW Iowa
    11
    I like the shop vac idea. I hadn't thought about that stuff needing to line up. You Tube is awesome I have watched a couple videos but will probably need to watch a few more before I really felt comfortable in the disassembling and reassembly of it. I made a call to a local Doughboy dealer and they said a liner would cost me $600-$700 for a 48-52" liner and $700-$100 for an expandable (up to 7'). Does this sound reasonable? If I had to replace it I would probably put in a deep end, with the expandable. I think I would ready to purchase this if I knew the liner would survive the move. Good deal or not I wasn't really shopping for different pool this year, but for $2000 I sure like the size of it, and it's only 3 years old. I'm still on the fence with this, but I really appreciate the input so far. Thanks.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It looks in good shape, but you are going to do quite a bit of work to move it from their yard to yours. I would assume you will need a new liner, and I would use that, and the fact that you are doing the work to take it out of their yard as price negotiation tools. Maybe give another call to the dealer to see how much a new pool of the same size costs.
    I think if it was me... I would take a step back and rethink what your getting yourself into taking down that pool.
    Price a couple of new pools out and then try to negotiate a deal. Your time is also worth something.
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
