Thread: Jandy Aquapure 1400, 125 and 194 codes
    I'm on my third sensor after less than four years of owning my pool. Both times my sensor went out, I received error codes 125 and 194. My first sensor was covered under warranty, but I had to buy the second one. Cold weather may be playing a role, as it happened both times after a freeze. I always clean my sensor and cell 3 times/year.
    Is this just luck of the draw, or should I be using something other than a tooth brush to clean the sensor?
    22,553
    Re: Jandy Aquapure 1400, 125 and 194 codes
    Welcome to TFP.
    If it's happened after a freeze both times I'd say you should protect the cell during freezing weather.
    Are you running the pump during freezing weather?
    Yes, I use freeze protect and haven't had any issues with my equipment freezing up.
    I though error codes 125 and 194 signaled a bad cell?
    Jun 2011
    Long Beach, CA
    2,790
    My sensor went bad this year after using it for just over a year. I did turn my output to 0% this winter for a month and when I started to use it again it was giving me no flow errors. The coldest water temp that I saw this winter was 58 degrees.
    My pool builder replaced the sensor under warranty and he said a lot of these sensors are starting to fail. The new sensor has a chip that does some diagnostics before the system starts to produce chlorine. With the old sensor that time was less than a minute and now it takes 4 to 5 minutes. I have not needed to clean my cell as it has been spotless every time I inspected it.
