Results 1 to 7 of 7
Thread: Scaling upon opening
    May 2011
    Los Angeles, CA
    228
    Hello everyone!
    I pulled off the cover from my pool and started shocking it.
    The tiles around the spa on which the cover was resting on has a lot of scale on it. It seems like the water had gone under the cover and stood over the tile wall which separates the spa from the pool.
    i tried using pool acid and it did dissolve a little but not all.
    what is the best way to remove the scale?
    any help would be appreciated!
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    30,419
    Re: Scaling upon opening
    Virtually all conversations about pool water chemistry have to start with current test results. Can you post them for pH, FC, TA, CH and CYA?
    May 2011
    Los Angeles, CA
    228
    Upon uncovering:
    FC= 0
    CC= 0
    CYA = 55
    pH = 8.2
    CH = 260
    TA = 90
    Temp = 73F
    Thanks!
    30,419
    Of course, you need some chlorine but your numbers look pretty decent. Nice to see the right amount of CYA already in your pool.
    So.......
    1. Lower your pH, sooner rather than later. Use muriatic and don't hesitate. The high pH is the main culprit causing the scaling and it can be doing other harm as well.
    2. Muriatic (diluted) is also the best way to remove the scale that has already formed. See if you can find an acid brush that you can use with the muriatic.
    3. At the same time, get some chlorine (probably about 4ppm) in the pool to keep it clean. How does your water look?
    May 2011
    Los Angeles, CA
    228
    Thanks for the reply!
    The water looks decent but is not crystal clear. It has cleared up a lot in the past three days the cover has been off and the pump running 24 hours.
    I adjusted the pH right away after pulling off the cover and then vacuumed, circulated the water a bit more (pump was running even when the pool was closed and under cover, though for a shorter time than 1.1 turnover per day) and started to shock the pool with the following readings:
    FC= 24
    CC = 0
    pH = 7.5
    CH = 260
    TA = 90
    CYA = 55
    temp = 76
    - CC ranged from 0 to 0.25 in the past three days it has been under shock.
    - the first addition of bleach lead to FC 36 upon my mistake but it quickly came down to 26 in like one day
    Right now I am doing the overnight FC test trying to get overnight FC loss to under 1 ppm. Today I got it to be 2 ppm overnight.
    I plan to add borates as soon as the shocking is over. I will wait till the FC dies down into normal range (4-9) before i start to add borax. I am not running the pool vac right now fearing damage to it due to high FC levels.
    30,419
    Nice work, Suley. You have things under control
    May 2011
    Los Angeles, CA
    228
    Thanks!
    But I must say it is all due to this forum that I can maintain the pool. I went from someone who knew nothing about pools to maintaining it not only independently but also better than a pool guy or a pool store!
    Now to get that overnight FC loss down to 1ppm or less....
