Results 1 to 9 of 9
Thread: My new project (re-plumbing my 1970 pool)
    Here's my other pool. It is in a mess. It is around 40k (I think like 36 to 38K). Since I've been reading this forum (noob), I believe I can re-plumb this pool myself. I'm going to give it a try.
    Background on the pool: It was built in 1970. It has PVC plumbing and old (no replacement parts available) gate valves. The gate valves were set up on a concrete floor and there is not enough room under them to cut them out (see photo)--unless I jack hammer the concrete. I'm not sure anything has ever been done to the pool, but I would guess the pump has been replaced a few times. It has an 1 1/2 Hayward pump.
    Here's what I want to do: Since I am sucking air from the old gate valves, sucking air and leaking water from a few of the connections into the pump and sand filter (that's an old one huh?), I am going to totally re-plumb the system so I can stop some of the air/water leaks.
    1st: I had to dig a hole next to the block retaining wall to get to the return/skimmer/bottom drain lines so I could cut them. I plan to come over the block wall instead of going through it.
    2nd: I will re-do the plumbing inside the pump station, but here's my worry. That sand filter hasn't been touched (other than me changing the sand). I'm not sure if the plumbing is glued or what. I don't want to risk cracking the flo valve.
    Based on the photos and post, what would you guys recommend on this flo valve? Can I find replacement parts for this one? Can a new one work on this type sand filter in case I break something? Should I just use a coupling into the pipe and not try to remove the fittings?
    Thanks, jed
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: My new project (re-plumbing my 1970 pool)
    As long as it's working OK, I don't see a reason to replace it as long as you have space for the couplings (looks like you do).
    Feb 2012
    Phoenix, AZ
    728
    Hey Jed, I am no master plumber, so I will leave it up to the other experts to assist you with that. BUT, I may be able to help with info about your multiport valve. Do you know what brand and model the sand filter is? If not, a picture of the entire unit (and label if possible) would be great. The next bit of info I will need is the measurement (center to center) between your inlet and outlet on your filter. Lastly, what size pipes do you have? Hopefully I can help you find a replacement valve!
    Quote Originally Posted by blakej
    The sand filter is a "Sea Blue" (see attached photo). The pipes are 1 1/2 inch. I forget to measure between the two pipes, but I got a good photo. See what you think.
    A couple more....
    I found this doing a search. It looks it would work in case I break something and have to replacement.
    Opinions?
    http://www.amazon.com/Hayward-SP0710X62 ... m_sbs_lg_5
    Oct 2009
    3,899
    Looks like one of the tried-and-true valves. Looks like those fittings aren't sch40, so I'd make sure to replace it with the right ones
    Quote Originally Posted by Melt In The Sun
    Thanks. Yeah, this valve has been going strong for years and years. I've have the pool since 1998 and not even opened the valve for cleaning (if it ain't broke). It does leak just a tad on backwashing, but not on filter. I think I've decided to cut the whole thing. The fittings will be changed out. I'm waiting on a friend in the pool business to come by and look at my intended project before I cut the pipes.
    How about that sand filter? A classic! That baby can clean and move some water. My pool is between 36000 and 40000 gallons and I've never had any serious problems with filtering.
    Thanks, jed
    30,431
    That's a beauty!! A new multiport and you'll probably get another 20 years!!
