Thread: Hayward super pump jumper for 220
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    203
    I need to know which way to move the jumper since the plastic broke
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    Using bleach since 2 Compupool SWG units have failed
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    203
    Pic 2
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    203
    Can't post more than 1 pic at a time in tapatalk
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    203
    Labek
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    203
    Re: Hayward super pump jumper for 220
    Got the motor & SWG swapped to 220! Now hopefully the breaker won't trip occasionally.
    Found what I needed here to make sure the wiring was correct... http://www.inyopools.com/HowToPage/how_ ... _pump.aspx
    Taped all the connections up real good for now until I can see about getting a replacement part, although as you can tell, this motor has been in use for some time. I think the plastic broke from getting brittle from heat.
    The motor does have some bearing whine now & then, but it would also be nice to have a dual speed pump, so not sure what the best route to go. Didn't want to spend a lot of money for a new pump this year, since I just spent $$ on the SWG.
    K-2006 Test kit
