Thread: Texture EEZ 3000
    Apr 2011
    Warner Robins, GA
    245
    Texture EEZ 3000
    Hi All!
    Does anyone have any experience with this product? I have plain poured concrete and really would like to spruce it up. I have some color swatches, but really would like to know if anyone has used this and what they thought! I like that it has texture additives in the mix instead of just plain stain. If not can anyone recommend a type of stain with texture additives to use? (Epoxy, Water based, Oil). I don't want to have to do it every couple years - need long lasting- as these projects cut into my Beer Time significantly . I cant use Acid (explain another time lol)
    http://www.innovativeconcrete.com
    Thanks!
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    Aug 2011
    Metro Atlanta, Georgia
    161
    Re: Texture EEZ 3000
    They don't really explain a lot, but it looks like what a company here does (commercial only) and they have had a lot of success. Having lived in Hawkinsville, have you looked into Kool Deck (I think that is how it is spelled)? It has been a long time, but it looked like the opening picture at that web page and concrete gets really hot around there. As you probably know, others will be along with ideas and opinions for you to consider.
    Off Topic: If you ever go to H'ville, look for the beach, from where the ocean was a couple of million years ago.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Aug 2007
    near the swamp
    806
    if you're in Hawkinsville, check out www.oxycool.com
    Apr 2011
    Warner Robins, GA
    245
    Thank you - I will check them out!
