Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Anyone using SOLAR SUN RINGS?
  1. Back To Top    #21
    Mar 2009
    Florida USA
    13
    Re: Anyone using SOLAR SUN RINGS?
    Quote Originally Posted by djcodyblue
    To answer some of the questions raised about the Solar Sun Rings.
    We have an in ground pool and live in the Houston, TX area. We received Solar Sun Rings for Christmas and have had them in ever since. Our pool today is 74 degrees and our friend's pool with more sun is 55 degrees. The rings cover about 70% of the pool and move along with the hose from the pool shark. Occasionally one will bend over a bit, but not often. Inflation....I'm probably slightly over inflated, but the under inflated ones collect more rain water.
    WE chose these over a full cover because we have dogs and didn't want them to get stuck in the cover if they fell in the pool.
    I agree. They work just difficult to deploy and store.
    Aqualogic/Aqua Pod SWG, Peble Tech, 15k gal pool & spa, Hayward pump/heat/filter, Polaris 280
  2. Back To Top    #22
    Cabana Boy's Avatar
    Jul 2007
    Sacramento, CA
    27
    Re:
    Quote Originally Posted by Wee Heavy
    Last year some similar comments convinced me not to try these. Although I love the idea.
    This year I intend to build my own similar 'Floating Solar Disks' based on plans I got on ebay.
    They are essentially sturdy frames with standard solar panel material attached. Obviously I am concerned that I might spend just as much money PLUS a lot of energy and not be happy. Ergh. I expect I will do it anyway.
    Hey Wee Heavy...just curious if you ever did build these, and if so, was it successful?
    14 x 32 x 6 (ave depth) 20K gallons - IG gunite pool. Challenger 1.5 hp pump and cartridge filter.
  3. Back To Top    #23
    Cabana Boy's Avatar
    Jul 2007
    Sacramento, CA
    27
    Well...despite the negative comments here...the wife and I bought eight rings. We're desperate for help, as last summer our pool never got above 78 degrees, even on 100 degree days. The wife wanted to try these as she doesn't like the look of a solar blanket (the pool is all you see from several windows in the house) and she doesn't want a roof solar water heater as she is afraid it will leak and ruin the roof.
    So I'd say we need to buy three more to get full coverage for the pool. However I am thinking they are helping. Our pool water was 78 degrees today, while the air temp was 89 degrees. That's the warmest its been this year.
    There is some problem with leaves getting trapped between the rings, instead of sucked into the water return. I've only been using them for a week, so I can't yet report on their durability. They were relatively easy to inflate, and a little bit of a pain in the butt, but I'd imagine a blanket is too.
  4. Back To Top    #24
    Jun 2014
    Roseville, CA
    341
    As a former user, let me chime into this ancient thread:
    The do work and they work well for about two years, 2011 - 2013, then they crack and are useless. For whatever reason, the plastic will not stand the test of time. I can't get a straight answer as to whether the plastic has been changed, but I have pool toys that have lasted 5 years. I would trade some performance for longevity.
    The web site annotates all problems with an explanation of what the user did wrong. Obviously, they don't feel it's their materials.
    My cost ended up being about $ 200 for two years worth of performance.
    If they have changed the vinyl, then I'd try them again.
  5. Back To Top    #25
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    We had the solar rings and they were more trouble than they were worth. Kept deflating and filling with water. Finally threw them out and went with a standard solar cover. I cut it into three pieces so it's easier to handle and works so much better it's unbelievable. And what we paid for the rings I could buy 4 solar covers and toss them each fall! Was not worth the money in my opinion!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
