Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Anyone using SOLAR SUN RINGS?
    These seem interesting but a bit more expensive than just a solar blanket. Anyone tried these yet? Wadda ya think? Do they set up as simply as they are advertised? How about storage while swimming or off season? Thanks!
    dp
    9x17 AG Vinyl "SPLASHER" w/outside struts (7/04), thru the wall skimmer & return, C900 Hayward Cartridge Filter (3/08), 1 hp Hayward Power-Flo II pump (4/09), Wanda Whale auto cleaner (3/07), new Wanda shoes (6/09), VinylWorks A Frame Step Ladder Entry System w/Gate (5/06), 5-1gal gravel-filled jugs hung w/ zip ties under steps to stop steps from floating, 1-3" TAB FLOAT under stairs (empty), More noodles, floats, and toys than allowed in any 9x17 sized pool!
    Oct 2007
    Cedar Hill, TN
    252
    Would like to know, too.
    What about plain bubble wrap??
    These solar rings or blankets always look like bubble wrap to me!!!
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    from previous discussion of these two alternatives, I have gleaned the following information.
    Solar Sun rings are not particularly effective. The purpose of a solar blanket is more to prevent cooling by evaporation (much of it at night) than to heat the water with sunshine. So if the vast majority of the water surface is not covered, you don't get the effect.
    Bubble wrap is a much thinner plastic, and will not hold up to the chems and sunlight as well as a solar cover.
    Sorry to burst your bubble wrap!!
    (couldn't resist that one!!!!! :P )
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jul 2007
    Northern NJ
    299
    I have them for an AGP and so far, I don't like them. They get very dirty, trap a lot of gunk and the water does not circulate at all when they are in the pool. I got them late in the season, so I can't comment on the heating aspects. I also determined that I needed a ring or 2 more than what was recommended for the size of my pool.
    I will give them another shot before I write them off completely since they were a bit expensive, but for now, I would not recommend them.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Heatmisr,
    Thanks for the info. That's what I'm looking for - real world data on how these things work. I think I'm just going to get a regular solar (bubblewrap) blanket for this season. I'm even thinking about getting the cheaper 8 mil (I have a small AGP) that's less expensive than TWO RINGS. It's my experience in just seeing these around pools that their 'shelf life' is limited anyways. Since we've never had anything - that will do better than nothing. Now if I can figure how to put some kind of a bracket and hoop to store the thing on the untravelled side of the pool ... .
    dp
    Jan 2008
    Forney, TX
    162
    If you're thinking about 8 mil you might consider going to 12 mil as is recommended on these forums. It doesn't cost much more, but will last a lot longer. Apparently any heavier than that will cost more yet, but will not yield longer life or better insulating value.
    I've read a lot about the solar rings on various forums and the consensus seems to be as described above, they don't work very well. Apparently if used in a windy area they get all bunched up at one end of the pool too (although this may be due to overinflation). They are also difficult to store when not in use and have to constantly be reinflated.
    Our pool adventure... click here
    TresW
    Thanks for the info. I hadn't looked here for info on the 8 mil vs 12 mil and will take that into consideration and I'll go take a look around the 'net to see what I can find.
    As for the solar rings, storage was one of my concerns, too. since there about 5 ft in diamater - that's a big FLAT space to give up or even if hung up on a wall.
    dp
    I BELEIVE!
    Mar 2008
    Florida
    81
    Thanks for info, sis in law had gotten them and said that the pool temp increased about 11 degrees in one week, outside temp staying fairly consistant with mild and sunny days. I was considering them, but the storage and cleaning issue alone have turned me off of them, ty again
    12-15k gallons capacity, 18'x34'
    2 main drains 4 returns 1 vacuum line
    pentair intelliflo 4x160 pump 200 sq ft media filter full width (~7' wide) swimout at deep end
    pebble sheen white diamonds
    San Diego
    22
    I use them in a free form pool. They help to keep the heat in overnight but I would have to agree that storage is kind of a pain.
    34'X 15' 3'-8' depth 22,000 gallon in-ground Grecian style built July of 2004, Blue Tahoe PebbleSheen, Poolpilot DIG-220 w/SC-60 SWCG, Pentair WFE-4 1HP filter pump, 6' S/S Waterfall and WFEDS-6 2 spd Waterfall pump, Letro Legend Platinum cleaner w/LA01N pump, Sta-Rite DE filter S8D110 53 sq. ft., 648 sq ft. East facing Solar panels w/Pentair LX 220 solar control, 6' Pewter Gray SR Smith Glas-Hide dive board on black powder coated cantilever stand w/SS hardware
    Heavier not necessarily better. We had a heavier cover and on our free form pool it was so unwieldy on the reel that we ended up not using it. One person could not do it alone. A thinner cover would have rolled easier and might have actually been used!
    upstate SC , 11K gal IG vinyl liner, 1HP superflo, Pentair DE filter, AE-Ti Heatpump, Aquarite SWG, Colorsplash LED,2 Bubblers, 4 Deck jets, Small interfab slide (3.5'), Coverstar opaque blue automatic cover.
    install completed 7/5/2007
    Sep 2007
    Gloucester County, NJ
    141
    so, my question is for those of you who have experience with them, is do you end up with pool water that is warmer than the ambient temperture? If so, by about how much?
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    San Diego
    22
    Quote Originally Posted by smuggs
    I use these but I really do not know how much they actually heat the water as I have solar panels on the roof. I don't think that I could get my pool water warmer than the ambient temperature at the end of a day just using the rings though but I don't really know. Our pool faces west and we get a lot of sunshine too. My main reason to use them is to help prevent heat lost at night.
    Sep 2007
    141
    RonI - good point on reducing the nightly temperature loss....that's what I really intended to focus my question on, but I must not have been awake enough after a long night with 2 kids not sleeping (6 yrs / 6 mths). In any event, what has been your experience on nightly temperature loss while using the rings vs. not using them? I currently seem to lose 2-3 degrees/night (high during day around 75-78; low at night 55; water temp 73 peak/70 low)
    San Diego
    22
    Lately, I have been seeing a 2-3 degree drop at night with the rings on but it depends on the water temperature during the day. When we had a heat spell a couple of weeks ago, I had 84-85 degree water but lost 5-6 degrees over night without the cover. The nights were probably in the upper 50's or low 60's. This last weekend with 84 degree water and with the cover on, I managed a 3 degree loss. The last couple of days, it's been much cooler during the day. I started at 81 and in the morning, it was 79. The next morning, it was at 77. We haven't had too much sun the last couple of days so the solar hasn't kicked on.
    riverheightsnancy's Avatar
    Aug 2007
    Flemington, NJ
    33
    Solar Rings
    I bought about 12 of the Solar Rings last season and that didn't cover the entire pool but about 75%. I live in Central NJ, and while it does get hot here (my pic is the last recent entry on the submit your photo for the slide show thread), our pool location has a lot of very tall established trees and we are up the "mountain" a bit so our overall temp can be 3-5 degrees different than just being in town. So we bought the rings. My biggest issue with the rings is that you have to inflate them! I could never get mine to look like the way they look in the photos. If you put too much air they curl on the sides, or fall into the water when underinflated. The directions say not to overinflate, it is really hard to know. They come all folded up, so getting the air in is difficult.
    My pool's ambient temp tends to be around 72-76 (I know that is kind of cold), the Solar Rings would bring the temp up to a more consistent 78-82. I hardly ever got over 86 unless it is really, really hot for an extended period of time and there is a lot of sun. My pool does get shade depending on the angle of the Sun.
    I am thinking of trying to return them to the maker as defective, because some of the rings get water in the air channels through the blow-up valve, so they actually have water in the part that is supposed to be blown up. I really wanted to put a solar blanket on a spool, but my husband didn't like the look of it and thought that the wind-up spool things was expensive. In comparison, the Solar Rings were just as expensive and more of a pain to blow up. I actually think that the idea is a good one, the application is flawed. IF the solar rings were a pop-up type of mechanism (like a pop-up pup tent) or a Hula-hoop type thing, they might work better. I tell you when I had to pump-up 12 rings by hand, and (when my hand got super sore) blow-up the rest, I was not a happy camper!
    If you have any other questions, I would be happy to answer them. I am sure I am sending them back.
    1960s Original Sylvan Pool
    Concrete
    @ 30,000 Gallons
    Hayward DE Filter
    2 HP Hayward Pump
    BBB believer!
    May 2008
    Bakerfield, CA
    2
    Solar Rings
    I bought 13 solar rings and a spa ring for my pool last year. It was difficult to inflate the rings, but once inflated it worked fine for about 2 weeks. After that, they started to deflate one by one. Within a month, all my rings had air leaks on them and could not inflate; which means that they could not stay afloat on the water surface. What a waste of money. It is such a great idea, but the design is defective. The spa ring however, still works fine and I am still using it. I would only recommend the spa ring. I would rate the solar rings for pool as an "F". I wasted a couple hundred dollars worth of solar rings.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    They suck. I wasted $300 on them. Hard to inflate, keep clean, and they blow all over the yard.
    Get yourself a nice solar cover.
    2003 Marquis Euphoria - 400gal
    Jun 2007
    North NJ
    6
    Last year some similar comments convinced me not to try these. Although I love the idea.
    This year I intend to build my own similar 'Floating Solar Disks' based on plans I got on ebay.
    They are essentially sturdy frames with standard solar panel material attached. Obviously I am concerned that I might spend just as much money PLUS a lot of energy and not be happy. Ergh. I expect I will do it anyway.
    Vinyl In Ground 18x36
    16,000 Gallon
    DE Filter
    No Heater
    Jun 2007
    Los Angeles, CA
    27
    I read in the ad copy that using the solar rings vs. solar blankets cuts down on mustard algae, my long-time nemesis. Anyone have any data on that? Though based on the comments above, I'm sticking with the bubble cover for now.
    25k 20x40 oval white plaster with overflow spa
    DE filter
    Aquabot T2
  20. Back To Top    #20
    Re: Anyone using SOLAR SUN RINGS?
    To answer some of the questions raised about the Solar Sun Rings.
    We have an in ground pool and live in the Houston, TX area. We received Solar Sun Rings for Christmas and have had them in ever since. Our pool today is 74 degrees and our friend's pool with more sun is 55 degrees. The rings cover about 70% of the pool and move along with the hose from the pool shark. Occasionally one will bend over a bit, but not often. Inflation....I'm probably slightly over inflated, but the under inflated ones collect more rain water.
    WE chose these over a full cover because we have dogs and didn't want them to get stuck in the cover if they fell in the pool.
    Since 1868: Watkins Products are the Best! watkinsonline.com Associate # 362645
