Thread: rubber plugs for CO2 tank
    etpools's Avatar
    Feb 2012
    5
    I used to work for a swimming pool service company. We would use a CO2 tank with a hose and rubber plug to blow out clogs in lines. Does anyone know where I can get some hose and the rubber plugs? The plugs allow air from the tank through the center of them and they have a compression wingnut you tighten to make it fit securely in the pipe. I cannot find the plugs and I have googled for days. I can find all sorts of rubber plugs and plugs with holes in them, but not the kind that has a hose connector on the top, a wingnut and allow air through the center. any help would be greatly appreciated.
    22,548
    Re: rubber plugs for CO2 tank
    It was probably custom made. You can make one with the proper parts. A bulkhead fitting and a winterizing plug and some drilling.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    What you seek is called a purge plug, and they are commonly used in pipe welding to fill pipes with argon for welding and such. Here's a link - http://www.techsouthinc.com/purge/tspurge.html #disclaimer - I don't know these folks, just found them on the internet.
    Apr 2012
    Bonner Springs, Kansas
    109
    Nice find! Add that to my bank of random knowledge
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
    etpools's Avatar
    Feb 2012
    5
    I knew there was a special name for them. It was bugging me like whenyou know the name of an actor but can't think of it. Thanks so much
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    No problem. You might find something by looking for hollow stem test plug, or some such, but I've always known them as purge plugs.
