Results 1 to 9 of 9
Thread: New In-ground Owner w/ SWG
    Jul 2010
    Calvert County, Maryland
    62
    Hello all, We just opened our In-Ground for swimming today at a balmy 72* Water temp.
    We have an Autopilot Digital.
    1 Main Drain, 1 Skimmer and 2 Return Jets
    Ran some numbers using my TF-100
    FC - 0
    CC - 0
    TC - 0
    Ph - 7.5
    T/A 110
    CH 120
    CYA 47
    Temp at time 70*
    Looks like I need to add Muratic Acid to lower the Ph, then aerate the best I can with my return gets.
    What should I set the output on the Autopilot to? Its a 0% right now and I need to bump that up before the algea begins.
    What else do you have for me?
    Thank in advance!
    29000 Gallon IG vinyl w/ SWG
    Pentair S220T
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New In-ground Owner w/ SWG
    Quote Originally Posted by nikolasmor
    I am not sure on the % to set it, but you should get some chlorine up to your recommended FC level using bleach/liquid chlorine, then set/adjust the swg to maintain that level.
    Your CYA level is a little low compared the recommended range for swgs of 70-80 ppm.
    By the way, it looks like you need to change the pool details in your sig?
    Jul 2010
    62
    Looks like I did double duty added the recommended amount and set the purifier to 40% Ouch, Now I am
    31 FC
    .5-1 CC
    7.8 PH
    100 TA
    and 43 CYA
    at 65*
    Looks like I need to add 62 more oz of Stabilizer. This will also lower the Ph so I will wait on the muriatic acid until the CYA is right.
    Also turned the Purifier off for a few days, will test and keep an eye on it.
    Pentair S220T
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Be careful adding CYA. It doesn't show up on testing for up to a week after adding it. So it's easy to overshoot.
    chiefwej
    Jul 2010
    62
    Good thought, I'll test closer to the eyelet and not by the diving board then add 1/2 the recommended amount. Wait a week and retest. In the mean time I will add 1/2 the Ph down recommended.
    Pentair S220T
    Jul 2010
    62
    Now we are at
    ~80CYA
    7.5 Ph
    13.5 FC
    0 CC
    13.5 TC
    Pentair S220T
    Jul 2010
    62
    Bumping this as I have algae growth starting at the bottom.
    7.8 Ph
    10 FC
    0 CC
    10 TC
    40 CYA
    120 TA
    I added 128oz Bleach yesterday, running the SWG on 24hr Boost and no difference in 48 hours.
    Thoughts?
    Pentair S220T
    Jul 2010
    62
    Added 32 oz of CYA as thats all I have on hand..will pick up more tomorrow to bring it up to 80. Extreme sunlight and replacing 12 inches of water since opening warrants this.
    Pentair S220T
    Jul 2010
    62
    Also dropped the Ph and am aerating to lower the TA
    Pentair S220T
