Results 1 to 8 of 8
Thread: Calcium hardness color question
    I was wondering if the addition of salt to a pool changes the degree of pink color you get after adding the R-011L reagent in testing for calcium hardness?
    The reason I ask is that I don't check it often (just because it rarely varies too much) and we have added a SWG since the last time I tested and now the water is just barely pink after adding the reagent. I tested 3 times on my own because I could just barely see color at all let alone a change and then I had the pool store test just to be sure I wasn't getting a faulty reading or having problems with reagents.
    Prior to adding SWG, I remember the water initially being bright pink. Since that's the only thing that has changes I was wondering if others had experienced this as well.
    12K IG gunite, Pentair Intelliflo pump and 1 hp Pentair booster pump, Posi-Clear Sta-rite cartridge filter, IntelliChlor SWG and EasyTouch system.
    Feb 2008
    Denton, TX
    5,061
    Re: Calcium hardness color question
    The addition of salt, assuming it is sodium chloride, shouldn't have an effect on the color of your CH sample. How old is your R-0011L reagent and where do you keep your test kit when you aren't using it?
    I'm glad to see someone else has the same problem. My kit is less then 1 year old (Taylor). Stored outside in a storage chest, in SoCal.
    18K Gals, Intelliflo VSD, Pentair Catridge, SWG, Solar & Gas Heat, Pebble Tec, Jandy AquaLinks, Pool Pal for Android.
    Feb 2008
    Denton, TX
    5,061
    R-0011L is one of those reagents that goes bad over time. This expiration process can be sped up by storing a kit in a place where it is subjected to temperature extremes. If you have noticed that the R-0011L is acting differently, replacing it would be advisable.
    Thanks, will do.
    Montreal Canada
    326
    What's the lot number on that reagent? Taylor has had a problem with lot 4064E.
    Thanks for the replies. I bought the reagents last May/June as part of the large TF-100 test kit, as such it doesn't appear that individual bottle has a lot number. I keep all the tests inside in cabinet so climate controlled. I will order some new R-011L and see if the problem goes away.
    BTW - my lot was 2043B.
    Are lots produced sequentially?
