Results 1 to 15 of 15
Thread: Polaris Issues
    Polaris Issues
    Hello all, I am having some trouble with my Polaris 380.. it sort of just floats around dumb and spends a lot of time leaning on it's side. Now, this is usually normal with the water is cold 45-55.. however, pool is now 75 and it is still doing it. I did a little research and read that the backup valve is suppose to only cycle on and off every four to six minutes. However, mine has always stays on and never shuts off. Ideas?
    PS.. I verified already that all three wheels move even when I move one, so I do not think the issue is with the cleaner itself.
    2003 Marquis Euphoria - 400gal
    Mar 2011
    Sunny Central Florida
    91
    Re: Polaris Issues
    You replace the float on the back of the unit? Running around on the bottom on it's side usually means float needs replaced, IME. Also fiddle with the squirter on the back of the unit. Point it towards the side that it's leaning to, to try to get it upright again.
    Your backup valve shoots water out of the little hole all the time? If so, it's broken. Good luck with a DIY repair. I couldn't even get the housing open!! I did stick something in it, to make sure the little propeller was turning properly.....I took mine off for a couple weeks, and just babysat the polaris and pulled it away from the steps when it got stuck.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Mar 2011
    91
    Re: Polaris Issues
    Also, do the wheel rotation test from the manual. You might be giving it too much water. Polaris' don't like to go too fast, LOL.
    Aug 2007
    near the swamp
    806
    Re: Polaris Issues
    I agree check the head float, the white ball on the cleaner head itself. Sounds like it's full of water and needs to be replaced.
    Re: Polaris Issues
    Thanks.. I checked the head float and there is no water in it.. but it was set a bit back so I moved it inward.. also my thrust jet was at 1 o clock.. I moved it to 11.. if those do not work I will remove or replace the backup valve.
    Re: Polaris Issues
    I think I found my issue..
    Oh and it's $99 plus tax at local pool store or $40 through Amazon.. lol
    Apr 2012
    151
    Re: Polaris Issues
    Don't buy the internals as well...looks like all you need is the case. You can save yourself some $$$$$
    Just did that on one of my pools...$25 installed.
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Re: Polaris Issues
    The wheels on my Polaris dont turn. I replaced the broken belts...Wheels still dont turn
    The back up valves squirts out water constantly and there is no water squirting out to spin the "paddle wheel"
    Do I have a bad back up valve?
    22' x 52" intex Ultra Frame pool
    Pasadena, MD
    12
    Re: Polaris Issues
    Quote Originally Posted by toytalk
    Sure sounds like it. The backup valve should only squirt water out of the reversing hole for approximately 30 seconds every 6-8 minutes. Sounds like your revering valve is stuck and no water is getting through the the base unit.
    Doug in Pasadena, MD
    21000 gallons
    Concrete/Plaster
    Aquapure SWCG system
    Pool owner since 2007
    Re: Polaris Issues
    My Polaris 380 backup valve is dribbling water out of the hole all the time, it's not a heavy flow, but steady. It does do the normal high pressure flow backup cycle every few minutes. My question is - I've noticed that the Polaris has less climbing power than it used to - it can't get up the walls to the surface anymore. Am I losing water pressure through the backup valve? Should there be no water at all flowing out that reversing hole when the backup cycle is not in progress? Note that I have done the wheel RPM test and it is almost exactly 32 RPM and I also do have the back nozzle set at 11:00. The tail sweeps normally, though I think it does not sweep as powerfully as it used to either. The wheels all spin together normally as well.
    This is my first post at TFP, thanks in advance for any advice! (And sorry if this is hijacking another thread to add a question, I just thought it seemed a relevant place for anyone else looking for Polaris troubleshooting info.)
    5000 Gal in ground Plaster
    DE filter, older than dirt.
    Re: Polaris Issues
    I have a polaris 165 it flips over when it works and I have had it about 6 years now. i would never buy another polaris product
    Aug 2007
    near the swamp
    806
    Re: Polaris Issues
    check the corners where the top meets the grey body base on the top/backside of the cleaner, the base usually splits there and it takes on water and causes it to be heavy and sink/flip over.
    RTV silicone, or pvc glue can patch it up after you drain the water out
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: Polaris Issues
    Quote Originally Posted by foothand
    My Polaris 380 backup valve is dribbling water out of the hole all the time, it's not a heavy flow, but steady. ... Should there be no water at all flowing out that reversing hole when the backup cycle is not in progress?
    There should be no water flowing out that reversing hole when the backup cycle isn't in progress.
    Sounds like you might need to replace the backup valve. If the case is in good shape and you can get it apart, you can buy just the guts of the backup valve. I have done just that and found the lowest prices on eBay.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Re: Polaris Issues
    Quote Originally Posted by CUTiger78
    Good luck!
    Excellent, thanks for the info! I will look into replacing the backup valve.
    Re: Polaris Issues
    I just ran into the same problem!
