Results 1 to 15 of 15
Thread: Is intex pump adequate?
    Looking for suggestions: We will be setting up (from storage) 16x48 intex pool soon and wondering if it needs a more powerful pump/filtration system. Had lots of problems with fine particles in the water and just seemed like insufficient circulation last year. The pump that came with the pool worked well with no apparent problems, but the water was just impossible to keep clear - the biggest problem was a persistent, very fine layer of stuff on the floor of the pool that would stir up once we were in and never seem to get filtered out. The water would look crystal clear, then once anyone was in and stirred it up, it was very cloudy. This went on all summer.
    Will buying a more powerful pump or different filtration system help? I tested the water daily and adjusted chemicals according to results. Loved the pool, but just never seemed to get the right routine to keep it nice.
    Any suggestions?
    Oct 2011
    New Caney, Texas
    414
    Re: Is intex pump adequate?
    Sounds like you need a bigger pump/filter. You can get a bigger Intex or many others will fit with some modifications. What size is it right now?
    http://www.troublefreepool.com/usefu...rs-t29612.html
    Welcome to the forum
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Welcome to TFP!
    Find dust on the floor of the pool needs to be vacuumed up. The filter will never catch most, let alone all, of the dust large enough to settle on the floor, so some stuff will always accumulate there, regardless of how good your pump/filter is.
    Mar 2012
    Amarillo, Texas
    341
    The first thing we updated on our intex was our pump and filter. It made a huge difference immediately, but it was almost the price of the pool.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Aug 2011
    Virginia Beach
    295
    I've had 2 or 3 inflatable ring type pools. The pumps that came with all of them were inadequate. A guy at the pool store sold me on a sand filter/pump upgrade, and that was the best thing I ever did for it/them. This year I'll be setting up a larger ultra-frame and I plan to use the same filter/pump combo. Based on past experience I expect the pump that comes with the pool to be too small to do the job.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Apr 2012
    Illinois
    41
    Seems all Intex pools I buy all need better pumps. Especially like the reg pool kits from the big box stores.
    AG Round Bestway EZ set 15' x 42"--3284 Gallons--Jaccuzi Lasor Sand Filter Model 160L, 16" diameter --- Pump Pentair Aquatools PMP 1HP
    P/N: AT2408610
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I live on a gravel road and would always have fine dust on the bottom. When the oem pump died I upgraded to the intex sand filter, it helped as it caught more stuff before it made it to the bottom and when it was stirred up. But Jason's right I still had to vacuum to get it all and because of the dirt road that is a daily chore if I wanted it spotless. I usually settled for 2-3 time a week.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    That pool comes with a 1,500gph pump. I have the same pool. That pump is way under powered and will not do a good job. You should look in to and invest in a Intex 4000 gallon per hour pump. Sell for about $150-170 dollars and the attachments fit your current pumps sizes, so no modifications of the houses are needed.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    You can look for a new or used pump/filter on craigslist, ebay or your local paper.
    Also if you use www.searchtempest.com you can expand your craigslist search to include surounding areas.
    But like the others stated, the 1500 will not do it for your pool. (it works great for my 300 gal softub)
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Thanks everybody - planning to order the intex 2500 and see what happens. Hoping that it will be an easy switch out. Makes you wonder if they sell these things with underpowered equipment on purpose. Either way, I appreciate all the great advice.
    Mar 2012
    Amarillo, Texas
    341
    Personally, because I hate proprietary equipment and I believe the problem with intex is not only their pumps but their fittings, I would go with a name brand pump and filter. It makes it so easy to do aftermarket modifications.
    18'x48" AG
    Hard Plumbed
    Just wanted to update since we got things sorted out. We ordered the 2500 gal intex pump from Amazon and it installed with no problem at all. Larger pump has absolutely made all the difference. I highly recommend this change to anyone purchasing the Intex Ultra Frame pools.
    Thanks for all the great guidance!
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    I too ordered the larger pump after I got my Intex. I have the 18x52, so the supplied 1500gph pump was waaaay too small. I upgraded to the 4000gph pump, but I don't think they make that one any more, so I'm glad I got it while I did. It's too bad, cuz it's a nice pump, not sure why they stopped selling it. But I'm sure the 2500gph is pretty good too since it also uses the larger B cartridges. FYI, order the cartridges from Amazon in bulk. It's so much cheaper than getting them from Intex or even Walmart.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    I too have posted on this board about the same subject...I have the 16 x 48 Ultra with the standard stock pumpt 635T and are having the same issues...
    I figured that by going ahead and ordering another system (Intex 1600 sand filter/pump) I will save myself a lot of time & aggravation. Expect mine sometime next week & will be posting the results...(can't be any worse!!)
    16 x 48 Intex Ultra; Intex 1600 sand filter/pump;
    TF50 test kit
    Crosby, Tx
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The Intex 2650 seems to make more people happy than the 1600. YMMV All based on my readings here.
    -- Guy --
