Results 1 to 7 of 7
Thread: Oily feel to water
    Oily feel to water
    I have an above ground 21' pool, new liner installed this year. Got it filled and has been running for about 1 month. Been in it, but water is chilly 76F. I just recently noticed that the water has an oily feel to it that wasn't there earlier. No sheen or anything I can see, just feels funny. Water looks crystal clear. Any one experienced this or have any ideas on what may be causing this?
    Don
    CYA: 70
    Ph: 7.6
    FC: 4.0
    CC: 0
    TA: 70
    CH: 200
    Salt: 3200
    Borates: none added, but planning on it.
    Aqua-Trol RJ
    DE filter
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Oily feel to water
    Does the water lose any FC overnight?
    Stays steady at 4 with the pump running 8 hours at SWG output 15%. I haven't really checked it in the am as I leave before daybreak. I will check it tomorrow morning.
    22,469
    Anyone in it with suntan lotion on?
    No lotion, that would have been too easy. I did ask everyone that was swimming. It is a weird feeling, kinda slippery, but not bad and the water will bead up on your skin, even tho you cant see anything there.
    Butterfly's Avatar
    South Carolina
    10,045
    Remember to turn off the SWG for the OCLT.
    You're done SLAMing when:
    Will do. Pouring down rain here now, will mess up my readings for sure. Might have to wait til Saturday night.
