Thread: need help i have a leak
    putting up a new intex pool and thought it would be good to install the thru wall skimmer mod ... all went well until last night when the water level reached the skimmer it started leaking. what can i do ??? ugggggg
    Intex 16x48 ultra frame
    22,551
    Re: need help i have a leak
    Did you use a butterfly gasket over the liner?
    How bad is the leak (drops or pour)?
    Yes I used butterfly gasket, and last night it was a
    Good trickle runNing down the side, this am seemed to be more of a drip
    I wonder if I went wrong by installing it before there was water weight on the wall?
    22,551
    I wouldn't think so. Did you use sealant on it?
    You might lower the water level and take it apart and see if there's anything obvious. If not you can try silicone sealant.
    Ok will do that i didnt use any sealant just the gasket thanks for the help
