Results 1 to 9 of 9
Thread: Help Please!!!!!!!
    Jun 2007
    Kernersville, NC
    45
    Help Please!!!!!!!
    4.19.12 @ 10:45pm
    FC - 4.5
    CC - 0.5
    PH - 7.2
    TA - 70*
    CYA - 30
    CH - 20
    Ok so I stared the season off with a lovely dark green to black pool.
    My pool cover had blown off in a wind storm, and all the leaves fell into the pool that were on top of the cover. The water is now blue but is very cloudy, I am still cleaning the cartridge on a daily basis because the cartridge is still collecting a lot. I guess my question is the cartridge is on its third season should I buy a new one? Also please help with the cloudiness I can not get it clear. Thanks!
    AGP (Wil-Par): 24' round, approx 14,000 gallon, 2 hp- 2 speed cartridge filter, TF100 test kit.
    30,419
    Re: Help Please!!!!!!!
    If it is collecting it is working and your pool is clearing up. You must be more patient. I assume you are running your pump 24/7.
    Jun 2007
    Kernersville, NC
    45
    Yup I am running it 24/7. Should I run it on high? Or does running it on low help catch more particles?
    30,419
    High. That will filter more water. Keep it clean. Help it by brushing and manually vacuuming as much as you can.
    Jun 2007
    Kernersville, NC
    45
    Should I be maintaining my fc at shock levels? And would it be ok to just run the auto vac?
    Jun 2007
    Kernersville, NC
    45
    I did a OCLT and had less then .5 fc loss, I am assuming that I have defeated all the algae at this point. Water still very cloudy is this normal?
    30,419
    You must be very thorough as you finish the process. Keep your FC at shock value until your pool is crystal clear. Run the pump 24/7 (on high) Clean/backwash your filter as needed.
    Yes, it is normal for water to be cloudy and it is normal to be very impatient.....don't be. Help your filter and pool by doing everything you can to get it cleaned up. Run the auto-vac, brush manually, etc.
    Even though you may have killed the algae (the cc's test does not prove that, the OCLT test does) you must still filter out the particles in your water that is making it coudy
    Jun 2007
    Kernersville, NC
    45
    Ok great, I am so thankful for this site. I am American so I don't like to wait for anything.lol thank you all for your input. I do at least feel like I am making progress.
    30,419
    Yes, you certainly are.....not only in the appearance of your pool but of your understanding about pool water management.
    Your next phase is likely "poolsparklyitis" wherein you become obsessed with how crystal clear your pool is......There is no cure but an occasional adult beverage will reduce the symptoms
