Thread: After adding CYA
    Nov 2010
    South Central Kentucky
    283
    After adding CYA
    How long should we wait to swim after adding CYA? I didn't see any notes on the container and couldn't find a topic on it here.
    Note: I'm adding using the sock method.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    38,475
    Re: After adding CYA
    If it is just slowly dissolving in a sock that could take up to a week. But I am pretty sure there is no problem swimming while it is dissolving assuming your water is clear and your FC level is appropriate.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep.
    You're done SLAMing when:
    Feb 2012
    Phoenix, AZ
    728
    I agree with Jason. I don't think you will have any issue swimming in the pool right away!
