Results 1 to 10 of 10
Thread: Threaded deck hole + umbrella
    Hi, I'm hoping to use a threaded pool deck hole I have to secure a pretty standard 9' patio umbrella I picked up recently.
    Is there some sort of an adapter, sleeve I need to buy? Searching has been tough for this, I guess the threaded holes were intended for other uses...
    Thanks.
    22,553
    Re: Threaded deck hole + umbrella
    Welcome to TFP.
    What size are the threaded holes? You could possibly use a PVC male threaded to slip adapter.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Feb 2012
    Phoenix, AZ
    728
    What size is the threaded hole on your pool deck? I am happy to research a solution for you
    EDIT: apparently I type too slow
    Thanks guys, nice keywords Bama, that helps!
    Not at home, but I think maybe it's a 1-1/2.
    So something like this is the answer?
    http://www.plumbersurplus.com/Prod/PVC- ... u=35323438
    Feb 2012
    Phoenix, AZ
    728
    txtodd, I think you are on the right track.
    When you get home, can you also post the measurement for your umbrella pole? I am guessing it is 1-1/2 or 1-3/4, but want to be sure!
    Bama, do you think a PVC adapter will hold up against a big gust of wind? Seems like it could cause a lot of torque on the base. If the hole is, in fact 1-1/2 in, it seems like there should be a metal fitting/adapter that could be used.
    Nov 2010
    Calera, Al
    271
    If it is threaded it could possibly already have a sleeve in the hole already. The threads could be for the cap. Can you post a pic?
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    22,553
    Those PVC adapters are pretty tough, but a big gust of wind and a long pole would snap it off. You could use a threaded to socket copper fitting if you wanted something metal. Or if the will fit inside a 1½" pipe you could just use a nipple threaded on one end.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    How deep is the hole? Just slip the umbrella pole into the hole, and shim it if it leans too much for your liking. gust of wind will break PVC fitting. Galvanized will rust, and i don't think you want to know the price for a brass fitting. That hole is probably for an umbrella, and the threaded end was possibly to fit it with a threaded cap during the winter months.
    Factory Warranty Station for:
    Jun 2011
    Greenwood, SC
    23
    Another option is to use the mobile umbrella base sold by Costco. I have 4 of them. They weigh over a 100lbs (sand and brick). I have 10ft umbrellas in them and can roll right next to the pool edge. Very happy with them.
    24K gal ( pool,spa,basin)
    Pentair Sand Filter, IG Plaster/ Inifinity Edge - Diamond Brite Onyx
    (2) Sta-Rite 2HP, Pentair 400K BTU heater
    Jandy Aquapure SWG w/ AquaLink, Tiger Shark Robot
    Quote Originally Posted by ROB N
    Believe that is the case Rob thanks. Put my umbrella in there and it's fairly snug, but it gets pretty windy at times, so a fitting would be ideal. Will shim until then...
