Results 1 to 10 of 10
Thread: Tips on draing waste water.
    Mar 2012
    Alton, Illinois
    5
    This may have been covered elsewhere. When I backwash and rinse my pool I usually drain the water into my backyard. Last year I almost flooded a neighbors house due to inattention. Does anyone have any tips on a better way to drain waste water? I have seen others just run the water down their driveways and into the culverts along the street. Due to the length of my driveway and no real culverts this just does not seem practical. Any tips or thougths would sure help.
    I have a Prima 52'', AGP that is 18x33, oval with a sand filter. My filter is 25'' 2.0hp with dual speed. the pool is 7 years old and was purchased at Atlantis Pools in Alton Illinois.
    Feb 2008
    Denton, TX
    5,061
    Re: Tips on draing waste water.
    You might need to plumb a route from your waste line to your sewer line.
    Mar 2012
    Alton, Illinois
    5
    seems like a lot of work and I'm not the most handyest of handymen. Thanks for the reply.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Random thought but all homes have a clean out trap for the sewer either in the back yard or on the side. Might have that close enough to the pool to just run the backwash hose over to it and send it down the sewer that way.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Mar 2012
    Alton, Illinois
    5
    Thanks Jamison04 that might do the trick.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Quote Originally Posted by Jamison04
    Not all homes do. Mines tucked away in the basement. Most new homes do however.......
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Quote Originally Posted by Leebo
    Very true. Guess it depends on the part of the country you're in as to where they locate those. Here they are commonly on the side or in back. Always landscaping around them here and have to keep in mind accessibility when selecting plant materials.
    APirateLooks@55: hopefully that suggestion will work for ya.
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Might also consider putting a timer on the pump to cut off the pump during the backwash, just in case you forget again...
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    If you have a storm drain close by, read up on your municipal code. I have a storm drain located between me and my neighbors house to help relieve a large underground spring, but we also both have our waste lines plumbed into it. Local code here has pools as exempt (if dechlorinated sufficiently).
    I can't see a huge issue when you backwash, but I can certainly see the issue when you're draining down for the winter.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    May 2009
    Mn
    198
    Yep, check your local code. Here it is illegal to drain anything towards the storm sewer,plus your runoff cannot cross into neighbors property and certainly not into the sanitary sewer system.
    Hate for you to get in trouble over waste water.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
