Thread: pool leaking?
    pool leaking?
    i noticed an area where my pavers are kinda lifting up and when i tap on them it sounds like theres nothing under
    leaking?
    thanks
    Apr 2011
    Warner Robins, GA
    245
    Re: pool leaking?
    Where in relationship to the pool are the pavers? How long have the pavers been installed? If these are pavers near the walls and are part of the deck, maybe the ground has settled creating a void. This happened at my last pool pool over the area where the plumbing went- the ground was not tamped properly and settled after about 6 months
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    Mar 2012
    Tampa Bay, Florida
    166
    Re: pool leaking?
    Unless your pavers are below the water level, the "pushing up" is not likely caused by a leak. I have had a problem with a few of mine pushing up due to a fungus growth starting below in the sand during very warm weather. The fungus is like a mushroom and was probably in the sand when they laid the pavers. The stuff looks like a black algae bloom. A few soaks of pool bleach killed it off. Also there may be some products to take care of that. When you can pull one of the pavers up without breaking it, take a look to see what is pushing it up.
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
