Thread: Last 2" of water
    Last 2" of water
    Im in the process of draining my pool but have a problem get the last 2" of water out. Does anyone have any good tips for me?
    Feb 2012
    Phoenix, AZ
    728
    Re: Last 2" of water
    What method are you using to drain the pool? A sump pump should do the trick.
    Is your pool in-ground or above-ground. If it is in ground, and you have a hydrostatic pressure valve, that could actually be letting water into your pool through the main drain (which actually prevents your pool from floating up due to high water table).
    Apr 2012
    New Orleans, LA
    36
    I bought a small sump pump from Home Depot for a decent price and it got most of the water out. The last little bit I used a mop bucket and a dust pan with a rubber edge. I would scoop, dump into the mop bucket and then pour it out the pool near a drain I have close to the pool. The small pump though can suck down to 3/16".....pretty good.
    Pool size: Approx. 25,000 gallons
    Filter: Nautilus Pac-Fab 48 sq. ft. DE
    Inground plaster pool
    https://scontent-b-dfw.xx.fbcdn.net/...089_9416_n.jpg
