Results 1 to 9 of 9
Thread: black dot still visible in CYA test
    Jul 2011
    Terre Haute indiana
    60
    Please do not hijack another member's thread! Always start your own thread, even if the situation is similar. Butterfly
    opened the pool today, checked cya. the tube filled to the top and the black dot was still very visable so its less than 20, should i use chlorine tabs to get it to rise
    19500 gal, IG, haywood s-200 sand filter & pump, 3/4 horse single speed motor, vinyl liner, tf 100 test kit, installed early 80's, Terre haute,In
    30,424
    Re: Any tricks to measuring CYA?
    The short answer is no.
    Feb 2012
    Phoenix, AZ
    728
    Re: black dot still visible in CYA test
    If you want to raise your CYA, I would follow the pool calculator and add either solid stabilizer or liquid stabilizer (based on your current and target numbers).
    Keep in mind that it can take solid stabilizer up to a week to dissolve. It will also lower your pH.
    Jul 2011
    Terre Haute indiana
    60
    ok thanks, will follow the pool calculator target levels
    Jul 2011
    Terre Haute indiana
    60
    any thoughts on solid stabilizer vs. liquid
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by REBARBEE
    Granular/solid CYA (a/k/a stabilizer or conditioner) is the most common. Lots of us buy it at Walmart. It can take up to a week for it to appear on the test, however, 24 hours after it has dissolved from the sock we 'assume' it is mixed in the water and adjust chlorine levels accordingly.
    The liquid CYA is pricy and it is instant.
    You're done SLAMing when:
    Jul 2011
    Terre Haute indiana
    60
    thanks will probaly use the solid just because i can get it local, would have to order the liquid
    Jul 2011
    Terre Haute indiana
    60
    the directions say to pour the stabilizer (granular) slowly into the skimmer but i'v seen on here that the sock method is best . is that what you recommend
    30,424
    Either way is fine. Without the sock, you should wait about a week before you backwash.
