Thread: Location of influent port for ORP
    Oct 2008
    Bonita Springs, Florida
    84
    I'm using the Hayward Sense & Dispense and OPR control; the tube for the influent is after the 4 cartridge filter. When I'm testing for chlorine, the difference between the pool water and the test cell is about 4 ppm (pool water higher than test cell, 2.0 vs. 6.0). I've tested for adequate suction from the test cell and it empties a small bucket in no time and there is plenty of water coming from the influent tube.
    Would I have more accurate results if I moved the influent port to a location between the pump and filter?
    Thanx.
    SW FL, 19K IG with spillover & cage, Goldline Pro-Logic PS-8, Hayward Sense & Dispense, Hayward Swim Clear 4025, Hayward Ecostar VS pump, Stenner MA pump, Aquabot, Hayward Aquarite SWG, Palin Pooltest 9, Helicol Solar.
    South Central NJ
    3,192
    Re: Location of influent port for ORP
    You are fine.
    Scott
    Owner of - PoolGuyNJ LLC
    Oct 2008
    84
    Any reason why there would be a 4 point spread between the pool water and the test cell?
    Aug 2010
    Austin, TX
    200
    Do you have a UV filter between the water filter and the test cell inlet?
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Oct 2008
    84
    Quote Originally Posted by shakenbake
    Nope.
