Results 1 to 7 of 7
Thread: Continious pool???
    Continious pool???
    My wife wants me to install (for lack of a better description) a continious flow/current system in our existing pool to allow her to swim against the current (like the ones they advertise on tv). I have googled trying to find just the pump or device that will do this, but with no luck. Any advise on where to get the equipment or an alternative idea?
    Thanks
    Re: Continious pool???
    You're probably looking for something like this, the BaduJet: http://www.badujet.com/build.html
    They are pricey though. I'm sure there is a much cheaper DYI option somewhere.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Putting one in an existing pool is pretty much impossible, as far as I know. A much simpler solution is a swimming harness that simply prevents you from moving as you swim...a quick google search for swimming harness pulls them right up.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    I bought my wife a swim leash so she can swim in place. It's just a couple velcro thinks that go on her ankles and it has a long bungee on it. I hooked a piece of rope to it and tied it off on a post. She gets to swim at whatever pace suits her without ever having to turn when she hits the wall.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Here you go starts at $6900
    http://www.endlesspools.com/fastlane.php
    Check out the specifications page for the details....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    I have a 3-jet 2-pump badujet system and I'm aware that they make one that just hangs on the side of a pool. This would work with the least amount of work. On the other hand mine was put in when the pool was built but I don't see any reason it coudn't be retrofitted in a pool.
    Northeast PA (Mt Cobb) 16,000 gallon in ground salt pool with all Pentair automation and Intelliflo VS pump. Also part of the pool is a two 5-horsepower 3-jet Badujet swim system. For heating we use a 384 sq-ft Heliocol solar pool heating system and additional solar from the 160 sq-ft house solar heating system.
    Jongig how do you like the unit? Does it work?
    Building year round use outdoor in ground pool in Wisconsin
