Thread: No Drain Acid Wash
    Jul 2010
    Richardson, TX (Dallas suburb)
    52
    No Drain Acid Wash
    Hey guys...I may seem ignorant, but I have been trying to find the directions for a "no drain" acid wash for about 2 hours. I was told to Google it and I would find what I needed, but when I do that, I get about 3 thousand hits, and after going thru 5 pages, still no clear directions...just a "kit" to order. I don't need a kit..I am fairly self sufficient, I know I can do this. Please advise.
    Brian, Richardson TX. 25K Plaster Pool, 1.5 HP Pump, Polaris 280 w/ 3/4 HP Booster Pump, 325 sq ft Cart Filter. This is my 3rd pool to convert to BBB method.
    Feb 2008
    Denton, TX
    5,061
    Re: No Drain Acid Wash
    Why do you think that you need an acid wash? Do you have scaling problems?
    A no drain acid wash is a fairly aggressive procedure that gives you little control over what happens. It will remove calcium scale, but will usually also remove plaster from areas that are not scaled, shortening the lifetime of the plaster.
    Jul 2010
    52
    Yes. The house was a foreclosure, then a flip...empty for at least a year. When I got it, pool had been cleaned up... But CH was only about 100. FC was 0, pH was off & CYA was 20. It took me a bit to get it into balance...after all we were trying to get our lives out of boxes, etc & it looked OK at first (yes, I got very good at looking at my water & knowing it was in need because the "diamond" sparklys were dull).
    Anyway... They had been using tabs for chlorine...traditional route of pool cleaning. By the time I had a balance with it, it had just started to show signs of scaling. I am now a full month into TFP balance and it hasn't gotten worse, but no better either. Like I stated...early stages of scaling. The plaster has a light tan to khaki colored staining that is randomly across the surface & it doesn't respond to brushing at all.
    Current readings:
    FC-8
    pH-7.3
    TA-80
    CH-320
    CYA-50
    I have not added Borax yet...waiting till I get other numbers stable.
    Temp-71
    My plan is to do a bit more testing first, but wanted to have the method info for "just in case". I have been researching the forums for all advice about the issues & planning my next move.
