Thread: Thinking about SWG but concerned with pool damage
    I am going on year number three of the pool. When we built, we had several builders push salt and others were admit about staying away from it. We eventually decided to go with a chlorine pool even though we went with one of the builders pushing salt.
    After two+ years of maintaining the pool, I am thinking about switching to salt to reduce maintenance.
    Several people I work with strongly recommend salt over chlorine due to the feel of the water and the simplified maintenance; however I have read comments online about the salt damaging limestone or other rock used around the pool. I also had someone come out for warranty work on the pool and I asked him what he would charge to install a SWG. He proceeded to talk me out of it saying it would ruin all my stonework and it was not worth it.
    Has anyone in the North Texas area had issues with limestone coping and a SWG?
    Phoenix, AZ
    Unknown pool size -Diving pool
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    576
    Re: Thinking about SWG but concerned with pool damage
    It's true that salt pool water can and will accelerate the wear and year on certain stone surfaces. Usually a sealer will prevent any damage tho. The maintence is a lot easier with a salt water pool. It's pricy up front but it can pay for itself with less maintenance and less chlorine or bleach to buy every year.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Feb 2008
    Denton, TX
    5,061
    There are cases of peoples natural stonework having problems supposedly due to the SWCG. It's not overly common though. The salinity of a pool (around 3000 ppm) doesn't even come close to that of seawater which is truly corrosive at 30,000 ppm plus.
    Aug 2011
    Texas
    45
    North Texas here and we have flagstone around our pool. We have an SWCG as well. I just applied this sealer made by dupont to all of the flagstone before putting the salt in the pool.
    http://www2.dupont.com/Stone_Tech_Profe ... ealer.html
    12k gal gunite, Sunstone Plaster, Pentair IntelliFloŽ VS+SVRS Variable Speed Pump, Pentair Intellichlor IC-40, Pentair CCP520 cart filter
