Thread: autofill and overflow
    Aug 2010
    Charleston, South Carolina
    77
    I've read a lot of comments on the pros and cons of adding an autofill to our pool build. It seems to me if you have an autofill it would also be a good idea to have an over flow drain. But I've searched everywhere for a place to purchase an overflow drain. I saw a pool under construction last summer that had a small metal grate about 2" x 3.5" which I assumed was the overflow. Any ideas on where to get that?
    I'm building the pool myself and have been ordering everything online.
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    38,267
    Re: autofill and overflow
    Is this an in-ground pool? The auto-fill containers I have seen for in-ground gunite pools have additional holes in them that could be used as an overflow ... assuming you set the container at the correct height or use a pipe to set the overflow level.
    Both of my pools have had these outlets plugged.
    Aug 2010
    77
    Yeah, it's an in-ground gunite pool. Your right the autofill does have holes for that purpose. Thanks.
    Feb 2008
    Denton, TX
    5,061
    Our overflow is exactly as you describe...a small metal grate about that size. We don't have an autofill though and I really don't think that I would want one.
    Jan 2011
    Richmond, Texas
    595
    Quote Originally Posted by 257WbyMag
    I wouldn't build a pool without a autofill. IMHO it is one less thing I worry about on a weekly basis.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Nov 2010
    Calera, Al
    271
    We have an auto fill and it does have an overfill. It is plumbed with a line that runs to an outdoor faucet and all I have to do is turn on the faucet to add water quickly and easy. Once it has finished filling the pool I smiply turn off the faucet.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
