Results 1 to 14 of 14
Thread: Pump Run Time
    Pump Run Time
    Will it hurt anything to run the pump 24/7? We have always run ours that way. I live in the south and it gets HOT AND HUMID HERE! And we tend to have algae probs as well.
    PEACE
    17000g AG Round, Sand Filter
    38,274
    Re: Pump Run Time
    It will only hurt your wallet.
    What pump do you have? A 2-speed allows you to run on low speed 24/7 for less electricity cost than running a 1-speed 8 hours.
    If you are getting algae, then you must not be testing and maintaining your FC at the appropriate level based on your CYA level. What do you use to add chlorine to your pool?
    If you post up a full set of test results, we can help get you squared away before summer. For now, you may want to review the Pool School link in my signature.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Pump Run Time
    I've been running my pump 24/7 since it started in Aug 2010. No problems yet. Wallet isn't too much worse off prior to the pump starting up.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    30,415
    Re: Pump Run Time
    Well, my fairly large pump runs, on average, eight hours daily and it's enough to keep the pool clean. I pay around 11 cents per kwh and that pump sucks up 2kw each hour or 22 cents hourly
    So, at eight hours daily, that works out around 50 dollars a month give or take. Running 24/7 would work about to about $150/month.
    I would just as soon keep my $100 bucks to spend on an adult beverage from time to time
    Re: Pump Run Time
    Yeah, there is definitely something wrong with your pool if you're running your pump that much and still have algae. Do you have a salt pool? If not, it might be worth investing so that your chlorine levels stay consistent. I run mine 8 hours per day and it's more than enough to keep the pool sparkling. You are definitely wasting money by running your pump 24/7, unless you get one of those new inteliflow pump. But sounds like the bigger problem is algae control.
    May 2009
    Youngsville NC
    395
    Re: Pump Run Time
    I run my pump 8-12 hours per day, normally. Also 1.5 HP, typically running 1.3 KW/hour. However, my rate plan is much cheaper than duraleigh's .
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Re: Pump Run Time
    Thanks, guys. About the algae: Had to close early last year due to algae. I just wanted to get all my Q's asked and answered before I began the " Swamp to Oasis" process...lol. Getting it filled up w/ water now and should begin shock and awe next week if weather holds out (been raining a lot...ugh). My first time trying the BBB, so I'm doing a lil freakin' out. But hopefully I will have my oasis soon!!
    PEACE
    38,274
    Re: Pump Run Time
    We are here if questions come up. Go shock and awe!!!
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump Run Time
    Do you have good test kit? A good test kit with a fas-dpd chlorine test will be needed, see link in my sig...I like the tf100, best bang for buck. It sounds like you have been reading the swamp to oasis post. Make sure you read the rest of poolschool (link in upper right of this page).
    Re: Pump Run Time
    >Jason: Didn't sound short...exactly how tall are you? Ha Ha Ha!
    >linen: Just got my Taylor tf100 Complete Test Kit the other day...YAY! Boy, does it seem confusing! And I have read almost this entire site! I'm driving my friends nuts spewing out pool info for the last week...lol.
    >All others answering my pump Q: My pump (of which kind I have no clue) only pulls about $25 bucks a month running 24/7. Worth it to me just to have my pool stay free of the leaves and sweet gum balls that drop in it almost daily...silly tree.
    PEACE
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump Run Time
    A filter collects the dead algae and nasties. You need to maintain the proper FC level based upon your CYA level and bather load to kill algae and other nasties. Running your pump/filter without killing the algae/nasties really isn't going to protect you. Usually 1 turnover a day is sufficient to keep the water clean. (Pool size (gal)/Flowrate (GPH) will give you an estimate of how long you need to run your pump then increase or decrease from that point till you get the water sparkling.) http://www.poolcaculator.com can help in getting the correct water chemical balance.
    Re: Pump Run Time
    >bobodaclown: Thanks for the info! I have looked over the pool calc, and just about every article on this site! I'm just a lil confused on some finer points, but am posting Qs as soon as they come up.
    PEACE
    Re: Pump Run Time
    What do you guys think the optimal times would be for runtime?
    For example for a 12 hr run time during daytime (ex 8am - 8pm)? or nighttime (ex 8pm - 8am)? What do you think would be best, if it matters.
    20,000L (5,200 gal) round AG pool, Hayward sand filter, 1.5hp pump, in the Laurentians, Quebec Canada
    Pool gets medium amount of sun, due to the house and surrounding trees.
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump Run Time
    If you have a SWCG then during the day. Otherwise I would say when you're swimming, or when do you normally look out at the pool and then a few hours before to give the skimmer a chance to skim the surface.
